Need some HELP!!
#43
ok, i just unpluged the maf, and took it for a drive about 10 miles, i wasnt expecting it to kick like a like a donky going into 2nd and 3rd, check engine light never came on, however i pulled a Po102 in the pending codes.i didnt fell the stutter or miss while drive, i did one time when i was at a light.
#44
New plugs and wires and check coil packs.
New upgraded injectors and tune.
New fuel filter and new pump,
Had the crank relearn done as well with no luck.
Maf sensor has been cleaned several times.
Changed the fuel pressuer regulator and pcv valve as well.
it was happening before all this was done.
#45
Honestly trying to help with the limited scanning capability over the net is hard. if i had a scan from hptuners it would be alot easier to work it.
Id try replacing tps first then maf. after that its beyond the limited info the hand held is getting you.
#47
well changed out the tps, drove it for about 2 hrs, it drove great, started heading home and the issues came back...i hate just tossing money at this truck... wish i just had the funds to take it in to get it looked at.
