Need some HELP!!
Old Sep 25, 2017 | 05:05 PM
  #51
truefire04's Avatar
ok so i purchased one of those obd2 readers, and purchased the torque pro app, and this is what i have...
Mode $06 report generated by Torque for Android
Vehicle VIN: Not present
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: Not present
Unit and scaling information are not supplied with the data from the ECU for this type of vehicle. Consulting the manufacturers service book for this information is recommended.
Test report:
TID:$02 CID:$04
- Lean to Rich sensor threshold voltage(constant)
Test incomplete or dependant test failed
TID:$02 CID:$10
Min: 90
Test result value: 90
PASS
TID:$02 CID:$11
Min: 375
Test result value: 376
PASS
TID:$02 CID:$12
TID:$02 CID:$20
Max: 500
Test result value: 16
PASS
TID:$02 CID:$26
Max: 70
Test result value: 6
PASS
TID:$02 CID:$30
TID:$02 CID:$40
TID:$02 CID:$46
Min: 100
Test result value: 100
PASS
TID:$06 CID:$35
- Lean to Rich sensor switch time(calculated)
Max: 124
Test result value: 35
PASS
TID:$06 CID:$41
Max: 137
Test result value: 111
PASS
TID:$06 CID:$55
Max: 124
Test result value: 32
PASS
TID:$06 CID:$61
Max: 229
Test result value: 93
PASS
TID:$07 CID:$0c
- Minimum sensor Voltage for test cycle(calculated)
Max: 0
Test result value: 65,491
FAIL
TID:$07 CID:$0d
Max: 1
FAIL
TID:$0c CID:$20
- Misfire counts for last/current driving cycles(calculated)
Max: 97
Test result value: 53,545
FAIL
TID:$0c CID:$30
Max: 126
FAIL
Old Sep 25, 2017 | 06:25 PM
  #52
truefire04's Avatar
ok, so i figured out how to turn on the miss fire monitors, and found out that cyc. 6 was missing pretty bad, so swapped that out and it seems ok, going to go test drive now.
Old Sep 25, 2017 | 08:12 PM
  #53
truefire04's Avatar
Just want to give an update. not that anyone cares, but that fixed my issue, still getting light random missfires, but only on the older Autozone coil packs, witch im going to replace with the ones i took off cylinders 1-4. Those where re-placed with AcDelco brand. I will never again buy off brand coil packs. at least they lasted a few years, seems as the original coil packs are still good. so they will be replacing Cylinder 5-8. Thanks for all the help. Was Greatly Appreciated!!!! and to anyone having issues, i rec-amend some kind of WIFI OBD2 reader and Torque Pro App.
This was the OBD2 Reader i purchased.
Amazon Amazon
