Need Opinion on 34" Radiator
Old Jun 20, 2005 | 07:57 PM
TigerFan187's Avatar
Default Need Opinion on 34" Radiator
Im about to finally get the E-fans,intake,injectors,etc.. put on and i had originally planned on getting the 34" radiator but Im having second thoughts. Yes the LS1/LT1 fans will work on the 34" radiator but do I really need it. Someone help me out on this. Its $230+ for one but is it needed. Mods below are current!
Old Jun 20, 2005 | 08:14 PM
Calbo's Avatar
I wanted to do it b/c in Jegs & Summit they say "gain 17 hp". Went with GM '05 fans and the larger radiator. Couldn't give a before/after # because everything was done at the same time. The best thing is the added space not having a fan clutch. Really helps when changing a belt.
Old Jun 20, 2005 | 08:16 PM
bluecajun5.3's Avatar
11 Second Truck Club
well with my mods i can cruise at the strip (that's bumper to bumper trafic, stop go, max mph about 15, 90* temp) with both fans on low rigged to a toggle switch my factory gauge reads 205* temp.
Old Jun 21, 2005 | 08:46 PM
KySilverado's Avatar
You don't need the 34" rad with the lS1 type fans. You do need the 34" rad with the 05 Truck Fans.
Old Jun 22, 2005 | 08:35 AM
Oh i know that IM just talking about from a cooling stand point. Would it be worth $250 for the cooling gains if there are any noticable ones. If it is gonna make me noticably cooler Ill do it!
Old Jun 22, 2005 | 09:56 AM
surely that cannot be correct my 03 stays around 185 in stop & go with just a rich idle tune & 160 stat
Old Jun 22, 2005 | 12:36 PM
You full of ****! You told me that at stop & go in the summer that it fluctuates from 185-210 just like mine!
Old Jun 22, 2005 | 05:50 PM
The 34" rad has to have additional cooling capacity. $230 bucks worth. In my opinion, no. Most of the horsepower I think comes from the removing he rotational mass of the fan. Not the cooler temps.
SloSVO
Nov 22, 2020 07:34 PM
AdaMax
May 16, 2016 11:35 PM
Tigger Welder
Oct 1, 2015 08:41 AM
old motorhead
Sep 29, 2015 08:22 PM
