need help on MSD
Old Oct 15, 2002 | 04:32 PM
RODNEY's Avatar
Default need help on MSD
Can some one tell me what and where the wire is to hook up the MSD window switch?
I have a 02 chevy 5.3 truck, also what pills are most of you running?
thanks
Old Oct 15, 2002 | 07:36 PM
really slow truck's Avatar
Default Re: need help on MSD
what are you having problems with? finding the tach signal wire? if so its the #10 wire, i just cant remember which side its on (red or blue) and what color the wire is. Maybe someone else knows. If not try searching for the pcm pin data or something like that. I just hooked mine up like 2 weeks ago and i already forgot <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
Old Oct 15, 2002 | 07:45 PM
GREGGO's Avatar
WHITE #10 wire <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Oct 15, 2002 | 08:02 PM
heh, thanks greg. but is that on the red or the blue side? or does the other side have a different color #10 wire?
Old Oct 15, 2002 | 08:05 PM
GREGGO's Avatar
I'm to lazy to go look at which side, but there was only ONE white #10 on my truck.
Old Oct 16, 2002 | 02:48 PM
RODNEY's Avatar
Where are you getting the white #10 wire from, is it under the hood or in the fuse box in the truck
Old Oct 16, 2002 | 03:18 PM
its not in either of the fuse boxes, its on the PCM. Look under the hood where your fuse box is, directly to your left will be another smaller black case with a bunch of wires running to it. That is where the wire is that you need to tap into
Old Oct 21, 2002 | 09:14 AM
RODNEY's Avatar
I hooked up the white #10 to the msd white wire where do you hook up the yellow wire on the msd i have tryed everything. can someone talk me through it.
(919)550-1636 RODNEY
Old Oct 21, 2002 | 09:57 AM
http://www.geocities.com/worm271/9_tnt.jpg
copy that link and paste it into your web browser address window. Go by the one on the bottom. Names each color wire and shows where they go.
SS94S10
Jan 3, 2019 01:57 PM
91LT16SpeedFormula
Oct 28, 2015 06:08 AM
91LT16SpeedFormula
Oct 17, 2015 08:01 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
