need help on MSD
what are you having problems with? finding the tach signal wire? if so its the #10 wire, i just cant remember which side its on (red or blue) and what color the wire is. Maybe someone else knows. If not try searching for the pcm pin data or something like that. I just hooked mine up like 2 weeks ago and i already forgot <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
its not in either of the fuse boxes, its on the PCM. Look under the hood where your fuse box is, directly to your left will be another smaller black case with a bunch of wires running to it. That is where the wire is that you need to tap into
I hooked up the white #10 to the msd white wire where do you hook up the yellow wire on the msd i have tryed everything. can someone talk me through it.
(919)550-1636 RODNEY
http://www.geocities.com/worm271/9_tnt.jpg
copy that link and paste it into your web browser address window. Go by the one on the bottom. Names each color wire and shows where they go.
91LT16SpeedFormula
Oct 17, 2015 08:01 PM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
