Need a fuel pump..Inline or In the Tank?
Old May 16, 2004 | 06:53 PM
CoonToot's Avatar
Question Need a fuel pump..Inline or In the Tank?
Well, the Whipple at 10 PSI is demanding more fuel. The stock fuel pump just can't keep up. My question is this: should I replace the in-tank stock unit with something bigger or just add an inline pump? Either way, can someone recommend a specific pump or setup? Just looking for help on this. Thanks!
Old May 16, 2004 | 08:58 PM
BlownChevy's Avatar
blownerator
25 Year Member
It would be easier to add the inline to your truck.
Old May 16, 2004 | 09:17 PM
CoonToot's Avatar
Any make or model you could suggest?
Old May 16, 2004 | 09:43 PM
parish8's Avatar
single digit dreamer
walbro gss340m is just what you need, i think most places sell that pump. i got mine from speed inc. it is an inline and will hold at least 9psi and a 75shot on a 6.0 or about 600rwhp. it is only like $120 or so but you will need to get a relay, fuse holder and some wire to get it wired up.
Old May 16, 2004 | 09:44 PM
BlownChevy's Avatar
blownerator
25 Year Member
Beat me to it!
Old May 16, 2004 | 10:42 PM
So this just goes in the fuel line outside the tank then. You don't have to do anything else after you install it other than hook the pump up to the battery right?
Old May 16, 2004 | 10:44 PM
parish8's Avatar
yep, on an ext cab it is a prety easy install, on a reg cab i couldn't see a good place to put it.
Old May 16, 2004 | 11:16 PM
BlownChevy's Avatar
blownerator
25 Year Member
Mine is located next to the fuel filter on the frame rail.
Step 130 shows a pic of a good location.
http://magnacharger.com/pdf/manual01.pdf
Old May 16, 2004 | 11:47 PM
thanks guys, i getting one of those too!
Old May 17, 2004 | 06:13 AM
CoonToot's Avatar
BlownChevy - Thanks for the link. That is where I would have to put it; now I can see a way to do it.
Parish - That Walbro was what I had in mind. You don't happen to have a schematic of the wiring do you? Or does the Walbro come with instructions on how to wire, but the parts need to be purchased separately?
Thanks for the help!
cosb
Aug 24, 2015 09:08 PM
Fast86z
Aug 23, 2015 12:35 AM
Sevex
Aug 22, 2015 12:12 AM
ss4chad
Aug 15, 2015 02:25 AM
black6spdz
Jul 16, 2015 01:32 AM
