my lq9 setup what do you think
Old Jun 3, 2010 | 10:34 PM
ou812sm's Avatar
Default my lq9 setup what do you think
ok i finally got my lq9 it has a gt2-3 cam in it i plan on changing the 918 springs to patriot springs with comp roller rockers as for the intake will be a tbss intake with a ls7 90 mm throttle body also changing to efan and i will be running a yank tt3000 torque conveter how do you guy think this will run i'm hopeing for good low end movement
Old Jun 3, 2010 | 11:19 PM
should run good.....i would sale that gt2-3 and do somethin a litte bigger, but u can roll with it the way it is. Congrats on the new purchase
Old Jun 3, 2010 | 11:20 PM
Atomic's Avatar
I have a gauge for that
sounds good to me, the gt2-3 will keep pulling up to 6400rpm
Old Jun 3, 2010 | 11:23 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Id skip the roller rockers but other than that sounds pretty good Im running the same cam in an LQ4
Old Jun 4, 2010 | 07:02 PM
ou812sm's Avatar
what's wrong with comp rocker arms also how is that cam does the torque come in right away or do you have to spin the engine to get the power
Old Jun 4, 2010 | 07:17 PM
Atomic's Avatar
Off-idle its not as good as stock, but you will get that with any cam. The torque curve is very broad, it just keeps pulling and pulling.
Old Jun 4, 2010 | 09:12 PM
budhayes3's Avatar
PT's Slowest Truck
The main thing that I know about the Comp roller rockers is that they are HEAVY...a lot of unnecessary weight on the valvetrain IMO. What Patriot springs are you going with, the golds? Seems like a lot of spring for that cam IMO, which also stresses out the valvetrain...what springs does Lingenfelter recommend? IIRC they sell that cam with LS6 springs, which can be had for about 60 bux new from places such as SDPC. If you plan on going bigger on the cam in the future that's a different story though.
Congrats on the LQ9 BTW, is this the same engine that you PM'd me about?
Old Jun 4, 2010 | 09:59 PM
1Bear's Avatar
Billy is right, with the GT2-3 cam, as long as you’re planning on keeping it, the Patriot Gold springs are way over kill. If you plan on keeping the cam and still want to beef up the valve-train I would just run the LS6 springs that Lingenfelter recommends with the addition of a set of hardened pushrods and at most, either a set of Harland Sharp or Comp Cam’s roller trunnion modified stock rockers. Now if you’re contemplating swapping cams, by all means the Patriot Gold’s are good springs.
simman22
Jan 21, 2017 10:27 PM
natejk
Nov 15, 2016 08:05 AM
zraffz
Sep 20, 2015 08:25 PM
CammedZ71
11
Sep 9, 2015 02:05 PM
zraffz
Sep 8, 2015 07:40 PM
