My DOD AFM Elimination Project
Old Sep 23, 2010 | 11:29 PM
Mrgoodwrench3's Avatar
Default My DOD AFM Elimination Project
About a year ago I decided to start researching eliminating the DOD. My truck is a 2007 Silverado 5.3 LY5. After a lot of reading and considering what the end result should be I decided to take on the project. I am almost done. I decided to put up a few teaser pictures. As you can see a simple cam swap has gone way too far. I should be done this weekend. I will post a series of pictures and parts that I used.
Old Sep 24, 2010 | 12:38 AM
max1's Avatar
Banned
looking good.. keep us posted on the pics...
Old Sep 24, 2010 | 01:19 AM
Silverado53's Avatar
Nice work! More specs on cam/springs, and all other parts used.
I should be doing this shortly on my '07 tahoe, although not that extreme. Mine will be staying in the vehicle. If you have any tips or tricks that made it go smoother please post them up.
Keep us updated.
Old Sep 24, 2010 | 03:28 AM
OK here is a parts list of what I did. There are other ways to do what I did. But this is what I found to be the best way for me, plus some additional recommendations.
2007 CHEVY SILVERADO 5.3 LY5
ELIMINATION OF THE DOD / AFM
1. Upgrade to Katech serpentine belt tensioner, new A/C Tensioner
2. ARP Head Bolt Kit
3. GM Head Gasket Set
4. GM Intake Manifold Gasket Set
5. GM Valve Cover Gaskets
6. GM Front, Rear and Oil Pan Gaskets
7. LS7 Lifters GM 12499225
8. Lifter Guides GM 12595365, I also used new bolts
9. LS7 Center valley cover GM 12570471
10. GM Valve Seals 12482062, 12482063
11. TEXAS SPEED AND PERFORMANCE PUSHRODS 7.400
12. Lunati 10 degree valve locks and retainers
13 IWIS Timing Chain---Call SDPC SD 3SR602
14. FERREA 6000 SERIES RACING VALVES--CALL SDPC
15. 1.7 FULL ROLLER ROCKER ARMS--SUMMIT RACING
16. ASP Underdrive Pulley ASP-549900
17. Wegner Motorsports water line adapters WA0214
18. TRU-COOL 40K Transmission Cooler
19. NGK Spark Plugs TR5GP
20. JBA HEADERS
21. CAM SPEC BY PATRICK G.
22. CAM PURCHASE: ENGINE POWER SYSTEMS (EPS) + DURABOND CAM BEARINGS
23. REDLINE OIL 5W40
24. BILLET ALUMINUM VALVE COVERS
25. CUSTOM MADE SPARK PLUG WIRES
26. LS2 THROTTLE BODY WITH SPACER
27. 3000/3200 TORQUE CONVERTER
28. CORVETTE/FAIRBANKS SUPERIOR SERVOS
29. GM OIL PUMP PICK UP O-RING
30. TRUFILTER LIFETIME OIL FILTER
31. UPGRADE TO LS7 MAF SENSOR
32. SCORPION VALVE SPRINGS 1218
33. ***SPONSORED*** CUSTOM MAF TUBE BY ADM PERFORMACE.COM
34. CUSTOM TUNING BY BLACKBEAR PERFORMANCE
I am sure there are somethings that I left out but these are the big pieces to do the project.
Old Sep 24, 2010 | 07:44 AM
blsnelling's Avatar
Nice build. It's cool to see another orange block
Old Sep 24, 2010 | 01:38 PM
skolman91's Avatar
If your sticking with the maf and that little valley filter your going to have un-metered air entering your engine. Not sure on how much but it will be there fwiw..
and what heads are you using?
Old Sep 24, 2010 | 02:13 PM
Preston129's Avatar
Good write-up, I've got a lot of questions now lol.
Are the heads milled at all?
What pre-load did you record with the 7.4 PRs?
Why the LS7 MAF and front cover?
Old Sep 24, 2010 | 03:18 PM
I am using 799 ported and polished heads milled .030. Ferrea 6000 series valve with a 5 angle cut. Finishing up the assembly today. Will measure preload. The LS7 MAF is the new style GM uses. The old one piece has the large bar across the inside. Not sure of any real benefit, but I will take free stuff all day long!
With Cam and Head Milling:
Static Compression Ratio: 10.68:1
Dynamic Compression: 8.52:1
Old Sep 24, 2010 | 03:29 PM
Preston129's Avatar
Originally Posted by Mrgoodwrench3
I am using 799 heads milled .030. They are fully ported. Ferrea 6000 series valve with a 5 angle cut. Finishing up the assembly today. Will measure preload. The LS7 MAF is the new style GM uses. The old one piece has the large bar across the inside. Not sure of any real benefit, but I will take free stuff all day long!
Interesting, can you grab the PN for it? I'd like to check that out.
Old Sep 24, 2010 | 03:38 PM
Part number for the MAF is 15865791
The tube is from Andy at ADM Performance.
