My 5.3 to 6.0 swap
Old Aug 6, 2011 | 07:41 PM
  #71
budhayes3's Avatar
PT's Slowest Truck
Hey man, I just realized that your truck has AIR...don't see that too often. You did a great job with the manifolds though, the look new
Old Aug 8, 2011 | 12:31 PM
  #72
brandon_6667's Avatar
Yeah you know I did notice that even here in CA I dont see it much. the factory lq9 manifolds didnt have it and it was a CA vehicle, maybe they did away with it in 02. I always wanted to take it off but i'm sure they would know that its supposed to have the AIR and fail me at the smog shop.. Damn CA, can't wait to start working on my 67 camaro again! (smog exempt!)
Old Aug 8, 2011 | 09:57 PM
  #73
budhayes3's Avatar
PT's Slowest Truck
Yeah brother, those Cali smog laws suck for sure...and spot smog checks too right!?
"Smog Exempt" sounds awesome though
Old Aug 17, 2011 | 04:26 PM
  #74
well I got my efans mounted, new belts installed, and all fluids in. Now i'm just waiting on my efan harness and then I'll be firing it up! definatley anxious now!
Old Aug 21, 2011 | 04:18 PM
  #75
Got it started up yesterday! Oil pressure jumped up to spec within 4 seconds, lifters were pretty loud but started quieting down after about a minute or so. No bearing noise or metal in the oil after warm up/cool down. You can definatley hear the difference from the 5.3, this 6.0 rumbles!
Everything sounds good and seems to be running fine except when i rev the engine the rpms stay up for about 5-10 seconds before slowly dropping down to idle. I'm not sure if its normal to do that untill you drive it for a bit but its still doing it after 10 minutes of driving, what could be causing this? its literally almost power braking at stop lights because of it revving. I have a cable driven throttlebody and I know the throttle butterfly is closing so what could it be? maybe a bad idle air valve ot throttle position sensor or something? My jeep used to have the same issue and it was usually the ide air valve. Let me know what you guys think? I'm planning on doing the smog and registration this week so Im hoping to figure it out in the next day or so.
Old Aug 21, 2011 | 05:19 PM
  #76
AJII's Avatar
Thats tune related. Retune will take care of that no problem.
Old Aug 21, 2011 | 05:39 PM
  #77
so I should send it back to blackbear for a retune?
Old Aug 21, 2011 | 07:11 PM
  #78
AJII's Avatar
Yeah, you'll have to.
I'd drive it some more before you do so that you can see if anything else needs tweaking.
Old Aug 21, 2011 | 07:22 PM
  #79
i see, I will email him asap. Is this common? what setting in the tune does it have to do with?
Old Aug 21, 2011 | 07:26 PM
  #80
rjwz28's Avatar
Man Motor club
Do you have the Autocal or are you going to have to ship your ecm?
