MS4 and LS3 heads
Guys, looking to run a ms4 or ms3 on an lq9 stock bottom end with ls3 heads, will there be enough ptv clearance with a factory gasket? has anyone tried this yet? will be a carbed motor in a light *** sn95 mustang.
No LS3 heads have valves that are so much larger that I am completely sure the MS4 won't work with out alot of fly cutting. and pretty confident the MS3 will need to be cut for also.
its not so much the lift as important to the duration!
When we make flycuts we usually try to go around .080-.090" and no more just to make sure the piston stays strong enough. We have cut more then that in extreme cases and been alright but I would try and stay safe with it.
