Motor swap? :)
Old May 5, 2004 | 06:02 PM
Barely Boosted's Avatar
Default Motor swap? :)
If i was to swap the the 5.3 what should I switch it to 6.0 or maybe vette motor. All suggestins are welcomed
Old May 5, 2004 | 06:22 PM
treyZ28's Avatar
I say LS1. Some vote HO 6.0 Cant lose either way. I like the aluminum block because i'm a sand box warrior.
Old May 6, 2004 | 07:48 AM
yellow4.8's Avatar
I have herad you can get a complete zo6 motor comp and all for like 5500 buck so i think that is a deal i would do that
01 yellow 4.8 flowmaster and hypertech
Old May 6, 2004 | 07:51 AM
Scream's Avatar
MOOBIES Moderator
I went with an LS1 for the weight savings.
Old May 6, 2004 | 07:58 AM
2003blue5.7's Avatar
I also am a fan of the ls1.... It's a blast to drive
Old May 6, 2004 | 08:22 AM
tooquick2beslo's Avatar
Wouldnt you have to change the PCM and all the wiring to put a LS1/LS6 in a truck ?
Old May 6, 2004 | 08:24 AM
You should but you can drive it with the truck pcm.... I am still driving on my truck pcm.
Old May 6, 2004 | 08:38 AM
01Blackerado's Avatar
Yeah it works well my only opt out from the ls1 is that its still geared to run like a car so it pulls more at the top end than it does at the bottom. since you have a truck the wieght diff is huge so you might want to switch the cam or something so you can get some low end torque back
Old May 6, 2004 | 09:26 AM
Scream's Avatar
MOOBIES Moderator
Nope...I still have the truck intake and all of the accessories, so there was no wiring changes at all. All you're really doing is changing out the long block--the intake, accessories, exhaust, etc all bolt up to the aluminum block.
And, the 5.7 has PLENTY of torque down low. Compared to a 4.8 it feels like a big block! I put a TR224 cam in mine and it feels NICE!
Old May 6, 2004 | 09:27 AM
treyZ28's Avatar
I can get you a crate LS1 for $2850 or so + ship
