motor mounts...
Old Aug 25, 2007 | 05:13 PM
silveradokidd_4518's Avatar
Default motor mounts...
ok i have tried the search but came up with nothing. i have looked around as well and cant seem to find anything. is there anyone out there that makes an aftermarket motor mount for the V8's?(polyurethane)
Old Aug 25, 2007 | 05:18 PM
Derek @ EDO's Avatar
FormerVendor
probably because the stockers are just fine, are you doing some sort of swap?
Old Aug 25, 2007 | 06:40 PM
ya im doing the 4.3 to 5.3 swap. just thought i would through some better motor mounts on there. but if the stockers are gonna be just fine then thats cool with me
Old Aug 25, 2007 | 07:12 PM
FormerVendor
you will be fine with the stockers. If you do a search you may come up with the PN's
I had them but i dont know what i did with the invoice.
you need the saddle mounts as well as the engine mounts. from a 1/2 ton 99-06 4.8. 5.3
Old Aug 25, 2007 | 07:34 PM
nightrunner's Avatar
Mr. Obvious
might try pm'ing Quik if you want some solid motor mounts
Old Aug 26, 2007 | 11:19 AM
i already have to stockers. came with the engine but i do need the frame mounts still which i might go pick up this week sometime
that might work as well...thanks man
Old Aug 26, 2007 | 12:28 PM
Quik's Avatar
5 year bitches!
find a set of stock truck ones and have someone box them in for you.
Old Aug 26, 2007 | 12:47 PM
thanks man
Go5.3tt06
25
Sep 4, 2016 10:25 AM
Glenn98ZM6
Sep 18, 2015 07:31 PM
dantheman1540
Sep 18, 2015 03:03 AM
03chevytruck
Sep 14, 2015 09:15 PM
