Milled heads
Old Feb 11, 2016 | 09:18 PM
6.Slow06's Avatar
Default Milled heads
Hey guys I'm currently putting a cam in my 5.3 with 243 heads. I want to mill the heads will i need new valves if I do mill the heads
Old Feb 11, 2016 | 10:42 PM
FFDP's Avatar
Why do you need to mill them?
Old Feb 13, 2016 | 12:35 AM
1FastBrick's Avatar
Custm2500's Rude Friend
No, They only cut the decks.
Make sure you check PTV clearance with the new cam as well as pushrod length.
Old Feb 13, 2016 | 11:15 AM
Depending on cam size I would cut them up to 35 or so. I personally would mock everything up, check PTV and decide how much to mill. My combo started at .120/.100 clearance (228/232 cam) and I decided on another .030 mill which put final PTV numbers at .090/.070 which i was ok with.
Old Feb 14, 2016 | 07:35 PM
6.Slow06's Avatar
I ordered a tsp 224/228 with the 7.4 pushrods
I want to mill them because I'm trying to get as much hp on all motor as I can maybe later do turbo or supercharger
Thanks for the help guys
guys
Old Apr 6, 2020 | 07:02 PM
RedXray's Avatar
100% Redneck
With a 36 IVC your LQ9 will be falling off power wise before 6600.
I think you're referring to my head/cam thread... not this old thread lol
Old Apr 6, 2020 | 07:04 PM
03sierraslt's Avatar
ya. Fixed. I scrolled to far.
Old Apr 6, 2020 | 07:55 PM
_zebra's Avatar
makes children cry
guys
i'd personally consider the boost goals before deciding to mill or not... if you're only wanting a few pounds, bumping the compression up won't be a big deal, but if you're thinking 10+ psi in a full-size truck, you start shrinking your tuning window a good bit on high compression.
yeah, my car's ~10.6:1 on 13psi, but it also only weighs 3500lb with me in it.
drewxjn
Jun 21, 2012 05:13 PM
La Blue 05
Jan 27, 2011 08:36 PM
v8
Aug 21, 2008 09:36 PM
GOT LS1
11
Dec 28, 2007 01:58 PM
