Safe mill on stock heads?
Old Aug 5, 2008 | 06:12 PM
v8
17,16,15,14,13,12,11 Drvr
Default Safe mill on stock heads?
going to have some heads milled and would like to know if I can go
.040 .045 .050 thousandths
cam is a 228 230 571 573 112 comp cam
Old Aug 5, 2008 | 08:40 PM
TarheelZ's Avatar
There have been some who have had .050 taken off, sure.
Old Aug 5, 2008 | 09:37 PM
v8
yeah I know just was wondering about this valve to piston clearance, thanks for the reply.
Old Aug 6, 2008 | 12:31 PM
BigKID's Avatar
.040 is safe for the deck thickness but P2V with your cam would need checking. I had .040 milled off my 5.3 heads when I had them on the 5.3 with a smaller 214/216 .55x cam with no problems.
Old Aug 6, 2008 | 02:44 PM
sickREDsierra's Avatar
i would check with a reputable machine shop on this.. tell them your head casting, planned gasket thickness, and cam, and they SHOULD know... if they are familiar with LS series engines.
Old Aug 6, 2008 | 03:00 PM
Mangled03gmc's Avatar
Baltimore Whore
You may also run into probs with the intake fitting..
John
Old Aug 6, 2008 | 06:27 PM
Hawk179's Avatar
measure it out. Thats the only way you will know. I would not want to take more than .030 off a stock head. Its pretty thin from the factory. Its like a block, why take it all off because when you have a problem you have no more room to fix it.
Rick
Old Aug 6, 2008 | 06:32 PM
v8
well richard at wcch will receive the heads tomorrow I sent him, there supposed to call me and talk about the setup. thanks for the advice.
Old Aug 14, 2008 | 10:10 PM
MASS seller approved
We typically never go over .030
Old Aug 14, 2008 | 10:19 PM
v8
that is a safe mill. thanks for the reply.
