5.3 with 01vette cam and which heads?
If your referring to this cam from an LS6
204/211 .525/.525 116
There are better cams that will get you more power.
If you use the 799/243 heads you should mill the heads to get the compression up to see the gains from the heads.
2 of our sponsors carry CNC Ported stage 2 head packages based on the 862's with larger valves and springs starting at $899 w/exchange
SDPC and WCCH
You will find there banners to the right--------------------------------------------------------------------------------------->
07NBSChevy
20
Jul 8, 2015 07:27 PM
