LS6 intake track results....
Old Nov 7, 2008 | 06:07 PM
southern_chevy's Avatar
I have no problem with low end now but all the aftermarket intakes dont really help till the upper rpm and usually loose low end.
Old Nov 7, 2008 | 06:19 PM
LMSeven's Avatar
Originally Posted by southern_chevy
Ya he said he wasnt all that impressed with it on his. It would be nice for someone to come out with an intake to help out the smaller motor and not loose much or any bottem end.
Look into the weiand street warrior intake. I wouldn't buy one until people start running them with different set ups and see their results.
Old Nov 7, 2008 | 06:23 PM
Bumpers's Avatar
I would do it just for the looks...i love the way they look
Old Nov 7, 2008 | 07:01 PM
Jessica's Avatar
Restricted User
No intake is going to help what happens when you move the IVC point past 40° ABDC.... say if you have a 220°+ cam on a 112°LSA...
The cam has to match the intake and the APPLICATION, but I forgot ***** size and cam size are inversely proportional around here. Luckily not having one means I don't have to "make up" for something.
Old Nov 7, 2008 | 07:39 PM
dlt76028's Avatar
uh huh huh?
Old Nov 7, 2008 | 09:09 PM
BlackGMC's Avatar
Resident Retard
Originally Posted by hirdlej
Are you running e fans or the mech fans?
Efans....
Just don't put so much cam in them and you aren't going to lose "bottom end"
honestly i have no problem with lowend on my truck, and i run a 220 cam... Lowend loss is usually in the tuning.... Besides my converter more than makes up if there was any loss...
Old Nov 7, 2008 | 09:15 PM
BlackGMC's Avatar
Resident Retard
I wanted to state again, i mainly did this mod to clean up the engine bay, which i still have alot of work to do... The mod did not make me any slower, plus it help my IDC, cause i put in bigger injectors... So since it performs the same but looks 10 times better, i think I will keep it... Also I really wanted to see what it would do... Since i have a 4.8 and most people usually just swap it out for a bigger motor, no one really sees how fast you can make it... I will be swapping to a 6.0l after christmas, because I think am about topped out now....
Old Nov 7, 2008 | 09:43 PM
ss454327's Avatar
I saw a test comparing the LS6, LS1, LS2 and Truck intake on an LQ9 and the LS6 and truck intake were almost identical on power. They said it wasn't worth the trouble to swap them out. The LS2 was crap and even with a 90mm TB it put down lower numbers than the LS1 intake.
Old Nov 7, 2008 | 11:07 PM
TXsilverado's Avatar
Most of that gain was probably due to the 200rpm higher shift point... I expect you would see the same on a 5.3L as well. A switch to a 90mm TB and a TBSS intake would have been worth more.
wrong. the guys on tech have figured out that the ls6 is better than the ssr with a 90mm, and ive decided that the truck intake is better than the ls6...
so MY PERSONAL OPINION is truck>ls6>ssr
ARC
57
Feb 21, 2022 10:54 AM
byrne_06
Apr 29, 2017 02:19 PM
The_W
Oct 28, 2015 09:00 PM
RONIN LSX
Aug 11, 2015 12:03 AM
Blackrat48
Aug 4, 2015 09:52 AM
