LS6 cam in a 4.8 nnbs
Old Feb 3, 2009 | 08:01 PM
dirt track racer 81's Avatar
Default LS6 cam in a 4.8 nnbs
Thinkin about an ls6 cam in my work truck. the little 4.8 needs some extra grunt gettin up hills. and considering it still has a warranty i would like a cam will a stock idle and that would run on the stock tune if i take it in for a warranty. i do not know much about it, does it require a different length pushrods? what do i need to convert to a 3 bolt cam? mine is a 1 bolt right?
Old Feb 3, 2009 | 10:26 PM
i was curiouse about the LS6 cam in the 4.8 as well?
Old Feb 3, 2009 | 10:32 PM
blackbeast ss's Avatar
i know the NNBS truck 4.8's have LS6 heads on them already so the LS6 cam will be pretty good for it. IIRC u need rods that are .050" shorter (7.350) because the LS6 cam supposedly has a smaller base circle cam but im not 100% sure
2005 Silverado's Avatar
SPAM HUNTER
I am running stock length pushrods in mine. Also low end grunt will be hurt top end will be improved.
Dustin
Old Feb 3, 2009 | 10:35 PM
SPAM HUNTER
Im pretty sure they need to be longer for a smaller base circle.
Dustin
Old Feb 3, 2009 | 10:39 PM
Dustin
thats what i thought. i may try an LS6 cam i didnt know the nnbs ones came with LS6 heads already though?
Old Feb 3, 2009 | 10:48 PM
SPAM HUNTER
idk, but yeah, i am sure longer rods are what is "needed" but i think .050 can be taken up by the lifters haha. I have had to problems shifting at 6300.
Dustin
Old Feb 3, 2009 | 10:50 PM
Dustin
ive yet to hit wot with it.. haha
Old Feb 3, 2009 | 11:23 PM
kbracing96's Avatar
LS6 cam has a .050 smaller base circle (diameter), so "IF" you wanted to keep preload the same on the lifters you need .025 longer rods, but they are not necessary, right Dustin?
Old Feb 3, 2009 | 11:24 PM
howd your motor idle with this cam. did it ever run with the stock tune?
