LS6 cam in a 4.8 nnbs
Old Feb 4, 2009 | 12:13 AM
  #21
RandomHero's Avatar
Originally Posted by Justin00SS
I didn't think LS7 cam would work in anything but GenIV like LS2 or LS7?
Can someone expand on this it makes me curious?
It's a gen IV cam like you said. It has a different cam position sensor(or one of those sensors I forget). Speartech(again not positive) makes a harness to relocate it. It's about $50 last time I checked.
Basically you can do it, but it severely reduces the cost effectiveness of the swap.
Old Feb 4, 2009 | 12:17 AM
  #22
Ok, so they (LS1 tech sponsor, I forget who) said it wouldn't work they were talking about "out of the box" so to speak. I gotcha.
Old Feb 4, 2009 | 12:19 AM
  #23
it just needs all the necesary parts to do it i guess but it will work?
  #24
RandomHero's Avatar
Exactly, it won't work out of the box, but it can be made to work.
Old Feb 4, 2009 | 01:11 AM
  #25
lucky77's Avatar
Banned
u just need a 3 bolt sprocket . . and get some hardened rods.. . ask "chevrolade"< he's running that same cam . on his NNBS . .
Old Feb 4, 2009 | 07:27 AM
  #26
nighthawk08's Avatar
lets stick to one discussion here...and thats putting a cam into a GMT900. both the ls6 and ls7 cam will need the 3 bolt cam sprocket that came on the LS7.
Old Feb 4, 2009 | 08:00 AM
  #27
Mark Johnson's Avatar
Say what...........
Old Feb 4, 2009 | 05:21 PM
  #28
chevrolade's Avatar
Im running thiscam on my 08'4.8,i used stock pushrods no problem,just swapped to ls6 yellow valve springs.yeslowend sucks but high rpms are nice.stall should take care of the low end problem.yes get the ls7 sprocket.
Old Feb 4, 2009 | 05:30 PM
  #29
2005 Silverado's Avatar
SPAM HUNTER
Originally Posted by dirt track racer 81
howd your motor idle with this cam. did it ever run with the stock tune?
First start up sounded a little rough, but it drove fine, didnt die really at all. But also this was on a stock "make my 4.8 run" tune after the v6-v8 swap. Also really it didn't seem like ALOT of tuning was needed after the swap.
I believe that 7.425 pushrods are optimal for the LS6 cam
Not really necessary like i have said several times, i see alot of high rpms cuz i drive like an ******* (right kyle) , and no problem so far
Agreed about shitty low end. Up top is nice. Actually today i had a buddy drive it so i could hear it from outside, IMO i can really tell when the cam kicks in.
Dustin
Old Feb 4, 2009 | 07:28 PM
  #30
006rcsb's Avatar
no one mentioned that that truck has active fuel management that will probably have to be turned off after a cam swap.
