LS6 cam in a 4.8 nnbs
Old Feb 3, 2009 | 11:29 PM
You already have a cam?
budhayes3's Avatar
PT's Slowest Truck
I believe that 7.425 pushrods are optimal for the LS6 cam
7.400 is stock in LS1 and LS6 with 1.7 RRs.
Old Feb 3, 2009 | 11:44 PM
kbracing96's Avatar
Originally Posted by dirt track racer 81
howd your motor idle with this cam. did it ever run with the stock tune?
Smooth as stock, you'll never know it has a cam just idling. It will run on a stock tune, might hunt a little when first started cold, but that's all I have ever noticed with them. I have one in the old mans '72 with the turbo 5.3. runs great
The difference was made up with longer valves in the LS6's
Old Feb 3, 2009 | 11:46 PM
Yeah, and probably need a fast or LS1/6 intake for that thing to bring when he gets on it.
Old Feb 3, 2009 | 11:58 PM
RandomHero's Avatar
Was that a serious comment? The ls1 intake actually flows worse and the ls6 doesn't warrant the cost of the swap.
Old Feb 4, 2009 | 12:03 AM
Not from the charts I've seen and the LS6 only outflows LS1 over 5000rpms.
Probably depends on who does the flow charts anyway. tomayto tomahto
With such long runners I wouldn't expect the truck intake to be worth much at all at top rpm so it probably does flow more at lower rpms.
Old Feb 4, 2009 | 12:08 AM
i have an LS7 cam but the LS6 would perform better right?
Old Feb 4, 2009 | 12:09 AM
I didn't think LS7 cam would work in anything but GenIV like LS2 or LS7?
Can someone expand on this it makes me curious?
Old Feb 4, 2009 | 12:12 AM
i have an 08, but i was told that it would fit in to previous years as well i guess with the right cam gear and everything?
