LS1/LS6 intake on truck engine
Old Jan 15, 2007 | 07:04 PM
  #41
Phantom's Avatar
11 Second Club
They say you don't gain anything from the LS1/6 intake unless you're takin it above 6200rpm...cost is one reason for going with an LS1/6 intake over the VIC JR intake like Parish has. I think he said he has close to 1k in his intake setup. They also say the Vic Jr is more for stroker type engines. Prolly lose a lot of low end on smaller engines like ours. Reading over on tech they still have problems with the cylinders goin lean with the LS1 intake...Haven't read too much about the LS6...cost to much for me
Old Jan 15, 2007 | 07:07 PM
  #42
Phantom's Avatar
11 Second Club
I'm doin my LS1 intake mainly for looks, but with my truck intake my HP climbs to 5200 then drops off real sharp and I'm hoping this might help out a little bit
Old Jan 15, 2007 | 09:20 PM
  #43
onebadrubi's Avatar
The truck intake has been proven to outperform and flow the ls1 intake. Sorry.
The ls6 outflows the truck and ls1. If your not reving over 6k the ls6 will nto be worth it. But for many of us truck guys reving to 6200+ this intake will allow our cammed 5.3/6.0's to carry their potential power into the low-mid 6k rpms. instead of running out of air around 5200.
Old Jan 15, 2007 | 10:40 PM
  #44
Kano's Avatar
Originally Posted by TheLadiesMan
maybe i missed this along the years but what are the gains from running a intake like this?
heres mine
https://www.performancetrucks.net/fo...d.php?t=360513
Old Jan 16, 2007 | 05:45 AM
  #45
tdrumm's Avatar
Originally Posted by bigcubes427
hey guys this swap was done by another person(i think it was HOT ROD MAG) they proved that the truck intake makes more power and a broader torgue curve than the vett/camaro intake................just an FYI
Just an FYI..... the test was done by Chevy High Performance Magazine. On a bone stock LS1, yes the truck intake held it's own against the LS6 intake. But then they swapped swapping cams. By the time they got up to a 212/218 cam (pretty small even for a 5.3) the LS6 was beating the truck intake in the full rpm range.
Considering most of the people here doing these swaps are running larger cams (220+ durations), or ported heads, or more displacement, or combinations of all three, I think this mod will prove itself to be worth while.
Take a look at the graphs in the truck dyno list thread. You'll see all sorts of N/A combos whose hp curves just stop climbing at 5200-5500 rpm. Why do these same cams pull all the way to 6K+ in LS1s yet stop well shy of that in smaller 5.3s? The answer is the intake cannot supply the volume of air needed in the high rpm range. Plenum volume of a truck intake is a full liter less than a LS6.
Old Jan 16, 2007 | 04:47 PM
  #46
s10mods's Avatar
Originally Posted by Z06 DREAMING
wow, I forgot about this thread! The pics helped me figure out exactly how I was going to do my swap a while back.
But I changed again to the Vic Jr. instead.
Is the vic jr better than the LS6 intake? Do they come set up for injectors, or do you have to drill them?
Old Jan 16, 2007 | 05:09 PM
  #47
ZR1 DREAMING's Avatar
Yes and yes. It also comes with fuel rails with the right pt#. That is what I have.
And an FYI for those of you saying the LS6 swap is not worth it unless you spin past 6000rpm.... In any cammed truck the stock intake stops power rediculously @ around 5200rpm, an LS6 does not lose power below that and only gains more above that. All this is due to the prior stated plenum volume increase. I would not waste my time with an LS1 intake.
It was a must for me to ditch the stock intake, when I first got down the track with my old H/C set-up my truck fell flat on it's face 2/3 to 3/4 of the way down the 1320. My mph was only 94! when it should have been easily over 100 It was actually rather embarassing.
I went with the vic jr. for the purpose of my new set-up being spun to 7200rpm. And to all together avoid the leaning issue which is still affected with an LS6 intake and the FAST intakes.
Old Jan 23, 2007 | 07:23 AM
  #48
eagleuh1's Avatar
Default water pump
Anybody here actually pulled the upper hose fitting out of their water pump and put another one back in. If so, how and did it seal good. I'm needing to do this on my 96 S10 Blazer so the hose will clear out of the way of my CAI. I have a 2005 5.3 with DBW tb and truck intake. Thanks
Old Jan 23, 2007 | 07:52 AM
  #49
onebadrubi's Avatar
can you do like speartech and cut it and reweld it?
Old Jan 23, 2007 | 12:33 PM
  #50
bluecajun5.3's Avatar
11 Second Truck Club
or you can swap the truck wp for a car style one.
press off the truck pully and press it on the car wp.
