ls1/ls6 intake
Old Jan 26, 2010 | 11:39 PM
03 True Fire's Avatar
Default ls1/ls6 intake
ok so i know you can swap on an ls6 intake manifold onto a truck block, but my question is wouldnt the ls1 fit right up as well seeing as how they are quite the same, only thing i see different is the valley underneath?! would that make the difference, or are the ports on both different as well?!
Old Jan 27, 2010 | 12:23 PM
also, do the bolts match up?!
Old Jan 27, 2010 | 12:37 PM
CJ Hungus's Avatar
Yes the LS1 intake will fit on a truck block but the LS1 is inferior to the truck intake flow wise.
Old Jan 27, 2010 | 01:03 PM
neilownz's Avatar
The idler pulley might need to be moved.
Old Jan 27, 2010 | 01:39 PM
1sic03x's Avatar
the truck intake also has better bottom end torque, while the LS6 has better top end horsepower.
Old Jan 27, 2010 | 05:02 PM
dirt track racer 81's Avatar
do alot of searchin.. this is covered almost every week.
Old Jan 27, 2010 | 10:45 PM
yes i saw a thread on it last week, i tried looking for it again but damn i cant find it, it was about the ls6 manifold. but i was wondering if the ls1 would be the same, so what manifold would be best suited other than the regular truck manifold?
Old Jan 27, 2010 | 11:17 PM
viciousknid's Avatar
Where's the Beef?
The ls1 intake would be downgrading from what you have. The only thing that will net you a gain is the LS6 but that will only gain at high RPM with a lot of mods.
Really the only thing worth the money is aftermarket stuff or just stay with what you have.
Old Jan 28, 2010 | 01:48 PM
ok cool, ive done some searchin on a FAST intake, but just wanted to touch up on this intake situation, i have a buddy with an ls1, but hes switch to new heads, cam, and ls6 manifold so i was wondering if it would be a good idea to scoop up the ls1 manifold. i think i'll stick with mine for now
Old Jan 28, 2010 | 08:30 PM
budhayes3's Avatar
PT's Slowest Truck
Good call, as mentioned the LS1 intake is inferior to the truck manifold, and a few members here have done the LS6 intake swap with little to no gain for a lot of work and dough.
