ls1 fan relay
Old Sep 29, 2003 | 12:40 AM
ThunderZ28's Avatar
12 Second Club
Default Re: ls1 fan relay
LOOKS GOOD
Old Sep 29, 2003 | 01:51 AM
sleepersilverado's Avatar
thunder:
i have used the in-expensive relays from auto parts stors that are made for like offroad lights. they work fine and are rated at i believe 30amps. so i put one for each fan. then looped the signal wire. the only thing is that they have two prongs that yould go to the lights because you would normaly have two lights so one will be un used. also i would use two because i blew a 20 amp fuse like a month after install so this leads me to believe that each fan dravs close to 20amps.
408: how many amps are the relays you are using rated for?
Old Sep 29, 2003 | 10:09 AM
ThunderZ28's Avatar
12 Second Club
THANKS FOR ALL THE INFO GUYS. IT REALLY HELPS
SLEEPERSILVERADO DO YOU HAVE A PART NUMBER IT WOULD HELP.
Old Sep 29, 2003 | 12:49 PM
no i do not. if i remember correctly they only had like two diffrent kinds. but the ones i have are the blazer brand 12v 30amps. but i do not have a part number on them.
Old Sep 29, 2003 | 11:34 PM
fabre01Z71's Avatar
Radio shack also sells relays for cheap.
Jared
Old Sep 30, 2003 | 12:22 AM
ThunderZ28's Avatar
12 Second Club
thanks guys i appreciate all the feed back its really coming in handy
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
Dawas
Sep 20, 2015 12:00 PM
FormulaZR
Sep 14, 2015 05:23 PM
