ls1 fan relay
Old Sep 28, 2003 | 10:42 PM
ThunderZ28's Avatar
12 Second Club
Default ls1 fan relay
i know this has been hashed out but where can i get this relay? i am recieving ls1 edit tuesday, and if highgmc sells me his ls1 fans i am going to need to get this relay so i can wire them up?.any help would be appreciated.as this is new teritory for me, im lost
Old Sep 28, 2003 | 10:56 PM
408 Stepside 01's Avatar
Default Re: ls1 fan relay
The relays that i always use on all my build ups are from GM. If you go to your local dealership, they have them. I use them for my fans and fuel pump. Whipple also uses these relays in there kits. The only bad thing is they are a little pricey.
Old Sep 28, 2003 | 11:08 PM
ThunderZ28's Avatar
12 Second Club
how much is alittle pricey? if its to pricey can i just go with a vsc?
Old Sep 28, 2003 | 11:42 PM
FILE's Avatar
Why not the Hayden A/C Thermo Relay from Pep Boys. I think its only $50.
Old Sep 28, 2003 | 11:47 PM
ThunderZ28's Avatar
12 Second Club
thanks, you have a part number?
Old Sep 29, 2003 | 12:06 AM
I believe it is about 80-90$. Plus it holds a lot of amps.
Old Sep 29, 2003 | 12:09 AM
ThunderZ28's Avatar
12 Second Club
THANKS 408 STEPSIDE 01. DO I NEED TO LOOK AT A BIGGER ALT? ALL I HAVE IS THE STOCK ONE
Old Sep 29, 2003 | 12:18 AM
No, you shouldnt have any problems.
Old Sep 29, 2003 | 12:23 AM
ThunderZ28's Avatar
12 Second Club
HEY 408 STEPSIDE 01 NICE PICS OF THE TRUCK, YOU DID A REAL NICE JOB. IS THE CONSOLE SPECIAL MADE OR DID YOU BUY AND HAVE IT FITTED?LOOKS NICE
Old Sep 29, 2003 | 12:31 AM
Thanks, I built the console out of wood and cut out pices of aluminum to match the holes, then wraped it in carpet.
