Ls1 edit question
Old Aug 30, 2003 | 04:26 PM
StreetSweepa's Avatar
Default Ls1 edit question
Can you program multiple engines with ls1edit? I mean, could i tune my truck and then go and tune some one elses as well or are there restrictions with that? The reason i'm asking is because i was looking into ordering it and it said $150/additional PCM. Thanks for the help.
Old Aug 30, 2003 | 04:45 PM
sleepersilverado's Avatar
Default Re: Ls1 edit question
no the initial cost is i believe 550$ and that will only do one computer. then for the each aditional pcm you want to be able to do it is 150$ for each. you can have a max of 4 pcms per edit cable. hope this is clear and helps.
Also if you get edit DO NOT plug it into any one elses vehicle. because the cable remembers vin numbers and if your cable is only able to do one computer and you plug it into your friends car playing around well you are screwed because it remembered his vin. then you would not be able to use it on your vehicle.
Old Aug 30, 2003 | 05:47 PM
Yep, that's all I needed to know. Thanks.
zblee
63
Jun 10, 2023 01:25 PM
nrmskate
Aug 11, 2015 02:44 PM
USMCvet0311
Aug 1, 2015 07:45 AM
Black-Syde
Jul 6, 2015 02:12 PM
