ls1 e fans
Old May 18, 2006 | 11:50 PM
  #21
Quik's Avatar
5 year bitches!
summit or ebay
Old May 19, 2006 | 01:17 AM
  #22
ltn's Avatar
ltn
hey quik would this be something that would work?
Old May 19, 2006 | 01:22 AM
  #23
ltn's Avatar
ltn
O yeah i forgot to ask do u think i would even need a switch since i live in san diego i mean does it get hot enough for me to even use the switch?
Old May 19, 2006 | 08:28 AM
  #24
Quik's Avatar
5 year bitches!
yes it works i run them in my truck, in my stangs, in other cars that i installed this same setup in. as for a switch i dont have one only real reason to have one is if you wanted them on say between rounds. but you can always add a switch. its not like you have to completely wire something up again. its a simple plug and play on the vsc
Old May 19, 2006 | 08:46 AM
  #25
nonnieselman's Avatar
Got through installing my LS1 fans last night, or should i say this morning at 2:30am. It wasnt bad at all. It just took a minute to make the mounting hardware.
I wired mine up to a relay that goes from the hot post under the hood in the fuse box, to the relay, to the fans. And i ran a Radio Shack Mini toggle switch to activate the relay, then ran a Green LED to the switched wire, so i will know when they are on and when they are off.
Tryin to get the factory fan off was the hardest thing! just keep gettin a bigger hammer if you need to. haha
Yall be good!
Later,
Jonathan
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
Dawas
Sep 20, 2015 12:00 PM
FormulaZR
Sep 14, 2015 05:23 PM
