LS1 e-fans = Silverado e-fans
Are the LS1 e-fans the ones everybodys putting in thier trucks? Also Is it the ones on ebay, and what else am I gonna need?
A lot of people are running LS1 fans, check on LS1Tech and you can find them pretty easy.
you can use any years LS1 fans and you can use LT1 fans too. yes they are all over ebay. i wouldnt pay more than 100 for them because if they get too expensive wait a few days and more will come up
got mine for $40 from ls1tech
check out nelson performance for the wiring harness, all plug n play and it saves soooo much time and work!
ld try and find 05 fans, I had overheating problems with the lt1's....
i have a/c cooling problems with the ls1's, i just need to make condensor to rad gap gaurds to suck more air through the fins
I'm more than happy with my 05 efan set-up....granted it's more expensive than some of the other options (since it requires the 34" rad), but the fitment is a direct bolt in and the fan operation has been flawless so far :)
where does most get the 05 e fans and radiator? So yall suggest that over the ls1 fans?
if you can afford it yea go for it and im pretty sure you can get it gm parts direct
