LQ4 crank bolt missing
Old Jan 31, 2015 | 11:11 AM
DAH32's Avatar
Default LQ4 crank bolt missing
Need a little help here.
Are some LQ4's not machined for crank bolts?
I just pulled off the balancer and timing gear and noticed this crank snout is not machined for a balancer bolt.
The engine came from a previous owner who had taken alot of bolts out of the engine and what not.
Seems some manuels and online sources say that balancer is held on by a bolt. Which makes sense, but does bolt not have to have threads? Does it tighten in way Im not aware off?
Thanks
Old Jan 31, 2015 | 11:16 AM
GMCtrk's Avatar
Never heard of that.
Is there a hole on the crank for a bolt? If so, maybe someone drilled out the threads if they got buggered.
Old Jan 31, 2015 | 11:30 AM
Gadgetized's Avatar
My engine was a 99, and the original crank was tapped for a bolt and the balancer was held on by a bolt. I have never heard of one not held on by a bolt. Can you take a pic of it?
Old Jan 31, 2015 | 11:42 AM
DAH32's Avatar
Yeah. Stick your pinky up in there. Smooth as babys butt. LOL
Old Jan 31, 2015 | 11:43 AM
DAH32's Avatar
Shall see.
Old Jan 31, 2015 | 11:45 AM
George C....'s Avatar
Formerly ScreamingL
threads are deep into the crank, typically a finger wont fit that far to feel the threads
Old Jan 31, 2015 | 12:02 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
How do you intend to install a crank damper without threads in the crank to hold the tool?
Quick answer is that all of the LS cranks are threaded. Yours may be damaged if the threads are gone.
Old Jan 31, 2015 | 04:52 PM
DAH32's Avatar
Question is. How far back are the threads and how long is the crank bolt? 4, 4.5" and or 5"?
Old Feb 1, 2015 | 10:09 AM
DAH32's Avatar
I see that now.
I guess the previous owner discarded the old crank bolt and did not know where it was when I purchased it from him.
Old Feb 1, 2015 | 11:16 AM
batboy's Avatar
11 Second Club
The OEM GM crank pulley bolt is TTY, so it can't be reused. You can buy an ARP bolt that is reusable.
