LQ4 build
Old Jun 24, 2011 | 06:50 PM
Will4993's Avatar
Default LQ4 build
Hey everyone new to the forum. Been reading through this forum for a while and finally decided to join. Got an 04 silverado ECSB 2WD with the 4.8. Recently purchased an LQ4 block and a set of l92 heads with patriot gold dual springs installed. Plan on boring the block to a 370 and forging for future boost plans. Trying to make 500-600 hp N/A. Is it possible? If so which intake, cam and injectors should i use?
Old Jun 24, 2011 | 08:28 PM
Beatdown Z's Avatar
Laid Back
500-600 hp at the flywheel should be no problem, if that's what you want.
Old Jun 25, 2011 | 02:57 PM
Will4993's Avatar
Bump...
Old Jun 26, 2011 | 09:50 PM
Will4993's Avatar
Come on guys give me some input.
Old Jun 29, 2011 | 11:16 AM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
What kind of transmission are you going to use? If boost is definitely in the plans the cam is not going to be a big one. I think its possible to make right around 500 flywheel hp with a low compression 370 I think, I wouldn't expect it to make much more though. Let me know transmission and stall and I will be able to spec a decent boost cam for the motor.
Old Jun 29, 2011 | 06:37 PM
Beatdown Z's Avatar
Laid Back
How far in the future are your boost plans?
Old Jul 2, 2011 | 01:37 PM
Will4993's Avatar
The transmission is gonna be a 4l80 with about a 3200-3600 stall. As far as boost plans go I figure within a year. Wanting to go with a procharger.
Old Jul 7, 2011 | 08:59 PM
Will4993's Avatar
bump!
Old Jul 8, 2011 | 04:16 AM
Amedee's Avatar
You heading in the right direction but if you gunna boost the motor do it all at once instead of going N/A then switching some parts for boost a boost cam won't be up to full potential till its boosted just fully plan before you jump into a build so you can get it done right the first time around and all your componets work together
lxcoupe
Sep 6, 2017 08:24 AM
Knightcrawler
Jul 20, 2016 03:29 PM
6.0l RST
Nov 23, 2015 11:30 AM
MA$TER_E
Sep 9, 2015 03:14 PM
