lowered truck looking for longtubes need help.
Old Jan 2, 2012 | 11:55 PM
bluebommer07's Avatar
Default lowered truck looking for longtubes need help.
i will be getting some lts real real soon and as of right i'm debating on these obx OBX Header GMC Tahoe Yukon 4.8L 5.3L 1500 99-06,OBX Racingsport Header or the famous pacesetter's. well my question is with me being lowered 3/6 will either one of these hang under frame, i don't want to spend money on them and one day hit a bump and tear them up because my truck is to low
Old Jan 3, 2012 | 06:47 AM
zero2sixT's Avatar
I run the pacesetters. The collectors don't hang below the frame rails. I can't speak for the OBX.
Old Jan 3, 2012 | 09:03 AM
907TBSS's Avatar
I run Kooks... can't say for sure but I'd say i'm lowered about 3" up front as well... any issue you will have does not lie with the collector but the crossover/Y pipe. I have scraped lightly before if I didn't take a parking lot entry/exit at the right angle.
It's nothing that would scare me away from going with LT's again i'll tell you that much!
Old Jan 3, 2012 | 04:43 PM
LS1TRUCKGUY's Avatar
as stated above, the headers wont hang below the frame at all, it just depends on the y pipe/crossover under the trans. with that being said, i have had lt's ypipe on my truck for over 5 years now with no issues besides scraping the crossover every now and then
Old Jan 5, 2012 | 07:45 AM
Would it be possible section/raise the crossmember to get a little bit more space
Old Jan 5, 2012 | 09:14 AM
907TBSS's Avatar
Why would you want to cut/modify a frame/cross-member to fit exhaust? It generally goes the other way around... path of least resistance. I say slap them on or do a test fit. I really don't think you'll encounter as big of an issue you may think you'll have.
Also it's more then just a X-member... were talking transmission here as well.
Old Jan 5, 2012 | 09:19 AM
Yea I think I'll go a ahead and throw them on and go frm there, o I meant raise y-pipe not crossmember sorry about that.
Old Jan 5, 2012 | 09:54 AM
texasglock23's Avatar
they don't come with a y pipe?
Old Jan 5, 2012 | 09:59 AM
Sn0wBa11's Avatar
11 Second Truck Club
I have the obx LT's and they don't hang below the frame at all. You might look into the new calspeed headers and the tsp LT's also
Old Jan 5, 2012 | 10:25 AM
cal speed is still out, should have some soon, TSP does not come with y's either. LPP, well, I am sure they work fine, but I will not recommend them to anyone due to the sellers **** poor tactics.
wrb002
Aug 31, 2015 12:00 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
MileHighSierra
Jul 22, 2015 11:19 PM
black6spdz
Jul 16, 2015 01:32 AM
Nimoryan
Jul 5, 2015 03:50 PM
