Low End?
Old Jun 9, 2005 | 12:57 AM
David1500's Avatar
Default Low End?
Well I towed my new pop up trailer behind me today to one of the state parks to get a lil practice in towing it and to see how the truck would handle it. The lil 4.8 is a pansy when it comes to getting the damn thing moving. So my question is............will a volant closed intake and the magnaflow catback help a lil on the low end, and what else may help?
Old Jun 9, 2005 | 12:58 AM
BlownChevy's Avatar
blownerator
25 Year Member
That should help a bit.
Old Jun 9, 2005 | 01:22 AM
Mr. Sandog's Avatar
In addition to the intake and exhaust you're considering, a cam like the one in my sig would probably help, maybe one with a little less duration, but the same lift. What that cam did for my low end was amazing, it completely change the personality of my truck. I'd recommend filling out the cam request sheet at Cam Motion and see what they tell you.
Old Jun 9, 2005 | 02:32 AM
David1500's Avatar
In order to fill that out I need to know a few things that I couldnt find..............
Like:
Rocker Ratio
Stock Intake Runner CC
Convertor Amount
I put on there a power range of 1500-5200, would 1500-4000 be more reasonable for what I will be doing?
Edit**I went ahead and put in the request, I'm sure they know such information for a stock LR4.
Old Jun 9, 2005 | 02:38 AM
LVSTOGOFST2002's Avatar
1.6 rockers, your converter is stock, so like 1600 leave the runner cc blank, they might finish it.....
Old Jun 9, 2005 | 04:03 AM
Mr. Sandog's Avatar
Like:
Rocker Ratio
Convertor Amount
Yeah, if you just tell them your truck is stock, they should have all of that info on rockers, runners, etc.
As far as power range, you did fine, although if you tow, you might want power a little lower. Do you have an automatic? If so, I would think you want power right off idle, so that would put your powerband from 700-5200 RPM's. If you have a stick, you could go higher.
Old Jun 9, 2005 | 12:04 PM
1.7 rockers.
Old Jun 9, 2005 | 12:08 PM
Mr. Sandog's Avatar
Originally Posted by Badzracing
1.7 rockers.
I thought the stock rockers were 1.7 as well.
zblee
63
Jun 10, 2023 01:25 PM
fctry286
Nov 22, 2015 03:26 PM
YenkoST
Aug 28, 2015 01:42 PM
JordanH
Aug 8, 2015 07:59 PM
OLD BULL
Aug 1, 2015 05:00 PM
