Loss of hp with exhaust cutouts
Old Dec 13, 2021 | 09:41 PM
RedXray's Avatar
100% Redneck
Originally Posted by THEPARTSMAN
yes at first I thought my mind was playing tricks on me. Cruising felt it little slower but I didn't think much of it till the other day I smashed the gas going 60pmh and nothing like no increase in acceleration rpm didn't go up much and it didn't down **** like it should because it just wasn't accelerating enough. I think is what someone said avobe that if the knock sensor code is on it pulls timing out of and it makes sense.. oh and my truck is not loud like most with no tail pipes
KR could be the culprit do you have access to HP Tuners or willing to pay a shop for a tune/retune? I had to lower the knock sensors sensitivity on my truck to get rid of false knock. I lowered the timing and boosted the octane and the KR didn't change. False knock shows up as a little random spike in the VCM Scanner. Real knock looks like a stair step across the scanner usually under sudden throttle or a heavy load. Buying HP Tuners was one of the best things I've done for my build. I'm not a tuner but I've learned enough to keep my junk running strong
You can see the stair step red line... this is real knock which can do damage.
Old Dec 13, 2021 | 10:02 PM
THEPARTSMAN's Avatar
Oh thats very cool. I was thinking of getting an hp tunners when I get to putting a cam, heads intake. Injectors and fuel pump. .. how much was the hp tunners?
Old Dec 13, 2021 | 11:06 PM
shakenfake's Avatar
Shlumpt
5 Year Member
HPTuners is $400 I believe
Old Dec 13, 2021 | 11:30 PM
RedXray's Avatar
100% Redneck
Plus a wideband gauge and two HP Tuner credits... but once you're setup you can flash different calibrations... like... forever... unless the PCM fails... then you'll hit the junkyard for a PCM... buy more credits... and tune tune tune away!
That said my AEM wideband o2 sensor died Saturday...
I miss seeing my A/F ratio... a new Bosch 4.9 replacement o2 sensor is $76
Bosch 17025 Bosch 17025
Old Dec 14, 2021 | 07:52 AM
shakenfake's Avatar
Shlumpt
5 Year Member
Call AEM, they may be able to hook you up with a replacement. I heard about a bad batch of sensors that died prematurely.
Old Dec 14, 2021 | 06:16 PM
RedXray's Avatar
100% Redneck
Mine is three years old. If the new sensor lasts three years I'll be super happy.
They just don't last long like narrowband's do. The SE X pipes bung is at the correct angle to help keep moisture away. I've read if you turn on the key and let the sensor preheat before starting it helps with longevity. Turning on the key you can see the word "HEAT" and LED's climb clockwise red to green on the gauge as the sensor preheats.
Old Dec 14, 2021 | 07:22 PM
shakenfake's Avatar
Shlumpt
5 Year Member
Hmm I’ll start doing that. Normally I don’t start the truck until all the dinging stops at the minimum
Old Dec 15, 2021 | 02:40 PM
dantheman1540's Avatar
Mines been taking longer to heat up then before, I wonder if it’s on its way out, I think it’s 2 y/o now.
06murder
Mar 31, 2020 05:08 PM
sleeperlqx
23
Dec 27, 2009 05:36 PM
Torque_Wrench
14
Sep 29, 2005 06:08 PM
greentahoe
16
Aug 3, 2005 08:37 PM
Vortech5300
26
Jun 19, 2002 07:27 AM
