Let’s talk bout exhaust
Old Mar 30, 2020 | 09:02 PM
06murder's Avatar
Default Let’s talk bout exhaust
Cam 5.3 with long tube header with 3” y pipe 2 3/4 pipe to borla xr1 muffler. Would true duals 2.5 exhaust work better??
Old Mar 30, 2020 | 09:15 PM
_zebra's Avatar
makes children cry
not really. it'll have the capacity to flow more air, but with just a cammed 5.3, you don't really need it. it'd just lower your exhaust velocity & maybe lose a little bit of torque down low.
Old Mar 30, 2020 | 09:54 PM
68Formula's Avatar
The only thing I’d add, is to ask whether you have the 2.5” muffler or the 3”. If it’s the 2.5” then you’d be best to upgrade to the 3”. Otherwise the combo is pretty set as is.
Old Mar 31, 2020 | 04:00 PM
00pooterSS's Avatar
I don't like the idea of a single 3" above 350-400 hp. You're getting close to that power and talking 2-3/4" pipe. Yeah you can do it, but you'll gain power if you don't
Dual 2.5 will flow WAY more than single 2-3/4. And if every little bit matters to you and you want room to grow in the future go duals. Don't do muffler shop crush bent exhaust though. That **** is a waste.
If you want a bad *** flowing exhaust setup that doesn't cost much just buy the speed engineering true dual setup with x pipe. It'll out flow either of your options there, probably cost the same or less, sound good, and give you plenty of room to grow in power without having to redo the exhaust again, and lose nothing. It's $420-480 depending on axle dump or rear exit setup and connects directly to the headers and comes with everything you need. It's hard to beat that
Old Mar 31, 2020 | 05:08 PM
06murder's Avatar
That’s what I was thinking... or make it myself, wanna do dB rods fuel cell for better exhaust routes.
TX Tahoe Z71
Feb 26, 2011 06:47 PM
TURBHOE
Jun 16, 2008 05:23 AM
circusboy
Jan 16, 2008 03:44 PM
el_cabby
22
Jan 19, 2006 11:26 AM
03red5.3
May 13, 2004 12:21 PM
