Lopey cam for a 5.3L?
Old Jun 5, 2008 | 09:43 PM
richierich14608's Avatar
Default Lopey cam for a 5.3L?
I love the real lopey sound on a cam, and was wondering what the biggest duration and lowest lobe seperation angle I could go with on a 5.3L 4x4 to get a real mean lope but not sacrifice too much drivability? Its an everyday driver!
Last edited by richierich14608; Jun 5, 2008 at 09:47 PM. Reason: Its a 4 wheel drive
Old Jun 5, 2008 | 10:02 PM
hirdlej's Avatar
Old Jun 5, 2008 | 10:07 PM
RandomHero's Avatar
pull a spark plug. That will give it "lope"
Old Jun 5, 2008 | 10:24 PM
95 bright teal's Avatar
Is it stock heigth? what gears do you have, do you plan on getting a higher stall, do you have any boltons
oh and the big question for any that are looking for cams HAVE YOU SEARCHED THE SITE?
Old Jun 6, 2008 | 02:01 AM
ricoc's Avatar
pick you true rpm range or you'll be wanting to change everything else to match a mismatched cam
Old Jun 6, 2008 | 02:18 AM
2005 Silverado's Avatar
SPAM HUNTER
THIS AND EXHAUST, all the threads have been like this lately!
Dustin
Old Jun 6, 2008 | 03:46 AM
jleonard711's Avatar
Wait, didn't you just post this 2 days ago?? --->"I am planning on doing a comp cam 220/220 on a 112 lsa, and was wondering which valve spring kit is going to last and perform well?"
https://www.performancetrucks.net/fo...d.php?t=419163
Sounds like you already picked your cam, but FYI that cam isn't going to sound "lopey" at all...
Old Jun 6, 2008 | 04:19 AM
viciousknid's Avatar
Where's the Beef?
You should just check different cam specs. If you don't see one you like have one custom made. Comp Cams website has a cam guide. If you don't want to lose TOO much low end go with an XR273HR 220/224 530/534.
They give you the RPM range of each cam so all you gotta do is get one that's in your range and has a good LSA and desired duration.
Old Jun 6, 2008 | 04:53 AM
stock48's Avatar
9 Second Truck Club
-212/212, .530", 108*
-215/215, .568'', 108*
Both those should have a good lope, and still have good low end. They are both ISKY lobes.
Old Jun 6, 2008 | 06:39 AM
RandomHero's Avatar
although I would be seriously worried about vacuum issues with a 108* lsa cam.
