Looks like I lost #7 piston
Old May 29, 2008 | 03:50 PM
  #161
CHEVRACER83's Avatar
DAMN CHRIS... YOU REALLY SCORED THOSE THINGS DIDNT YOU....
OH WELL WHEN ALL ELSE FAILS GO BIGGER
Old May 29, 2008 | 04:11 PM
  #162
thunder550's Avatar
High on diesel fumes
I'm not sure if the pistons will have to be custom or not. Hopefully they are just an off-the-shelf size so we don't have to wait for customs to be made.
Old May 29, 2008 | 04:15 PM
  #163
budhayes3's Avatar
PT's Slowest Truck
Wow, those cylinder walls look like hell!
Old May 29, 2008 | 04:48 PM
  #164
DONT WORRY BRO.. DEPENDING ON THE COMPANY... IT WONT TAKE THAT LONG... ITLL ALL BE COOL, AND YOU WILL BE UP AND RUNNING AGAIN SOON
Old May 29, 2008 | 05:00 PM
  #165
BlownChevy's Avatar
blownerator
25 Year Member
Smaller displacement motor and more boost.
Old May 29, 2008 | 05:03 PM
  #166
thunder550's Avatar
Why do you say that?
Old May 29, 2008 | 05:04 PM
  #167
BECAUSE BRIAN DOESNT LIKE THE FACT THAT A TURBO IS MORE EFFICIENT THAN A RADIX
Old May 29, 2008 | 05:26 PM
  #168
7845's Avatar
Banned
that sucks. it might be cheaper to do a 408 again and scrap that block. depending the cost of parts
Old May 29, 2008 | 05:29 PM
  #169
BlownChevy's Avatar
blownerator
25 Year Member
Becasue you can operate your power adder in its efficency range......have less problems with the motor, and make BETTER HP. I have discussed this with Rex in detail, I am sure he will comment on it.
As for dipshits comment, I will take 600 RWHP and 18mpg any day of the week
Old May 29, 2008 | 05:32 PM
  #170
thunder550's Avatar
Finding a good 6.0L block is an issue. Rex has one, but it's the older style that takes the different length head bolts, so I'd have to get new studs, which adds to the price. Also just talked to him about running a 5.3 block bored to 5.7 specs and running my 4" crank to make a 383 and he thinks I'd be better off working off the 6.0L block. Cost of boring/decking/line honing a new block would likely offset the savings from running an off the shelf LS1 piston. I really think that sticking with the block I have is probably going to be the best deal.
Brian, I did talk to Rex and he thinks that going another .010 over on my current block is going to net the best results.
