Looks like I lost #7 piston
Old May 29, 2008 | 05:34 PM
  #171
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by thunder550
Brian, I did talk to Rex and he thinks that going another .010 over on my current block is going to net the best results.
Since you have it already I would agree.
Old May 29, 2008 | 05:36 PM
  #172
thunder550's Avatar
High on diesel fumes
Don't pee in this motor ok? I think that's what caused problems in the first one.
Old May 29, 2008 | 05:38 PM
  #173
BlownChevy's Avatar
blownerator
25 Year Member
I cannot gurantee that.
Old May 29, 2008 | 06:05 PM
  #174
trever1t's Avatar
2nd fastest 5.3 ECSB
BC pisses pure boost!
Old May 29, 2008 | 06:19 PM
  #175
s/c'd cav's Avatar
i dont think ill have traction issues , im gonna try and keep a low stall speed , and ease into boost , it wont net the best times but should keep the tires stuck , if i do get a little then time for a straight axle and slicks
.010 over might leave a few light scratches in the bore , might wanna shoot for .020 , or which ever piston is readily available , but gotta get to .010 before ya get to .020
Old May 29, 2008 | 06:23 PM
  #176
CHEVRACER83's Avatar
Old May 30, 2008 | 01:04 AM
  #177
Spoolin's Avatar
GFYS and STFU
I'd do whatever Rex suggest but I like the idea of a new block too. It might be more cost efficient to reuse this one but if she seizes again for some odd damn reason and you have to pull it again there goes all your savings. Short term reuse this one, but if your thinking long term than I say get a new block.
Old May 30, 2008 | 01:23 AM
  #178
chevyguy7802's Avatar
I do like the 383 idea tho.....
Old May 30, 2008 | 05:31 AM
  #179
TG02Z71's Avatar
So was there as theory on what caused this problem? Did you wash the cylinders with gasoline?
Old May 30, 2008 | 07:04 AM
  #180
zippy's Avatar
Wow, I'm a bit late on this, but wow. I'd go with the .040 over and not worry about it. I preferr more cubes and less boost, that is commonly the safer way to go.
