looking for a used 5.3 or 6.o.
Old Jan 22, 2008 | 11:00 AM
Exclamation looking for a used 5.3 or 6.o.
i want to swap my 4.8 with a 5.3 or 6.o but having trouble finding them.
Old Jan 22, 2008 | 11:07 AM
sickREDsierra's Avatar
have you looked on ebay??
shitloads of 5.3's..... if you are swapping though, may as well do a 6.0
Old Jan 22, 2008 | 11:10 AM
dlt76028's Avatar
Ebay, Craigslist, Car-part.com
Old Jan 22, 2008 | 11:31 AM
DamnYankee's Avatar
formerly Moze (2/24/2012)
Where are you located? I have a 5.3 and trans...
Old Jan 22, 2008 | 11:32 AM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
+1
Old Jan 22, 2008 | 12:34 PM
SmokinHot98's Avatar
Where are you Located?
Old Jan 22, 2008 | 12:51 PM
im located in Devine which is 30 miles south of san antonio.
Old Jan 22, 2008 | 01:17 PM
what r you runnin in the 1/4?
Old Jan 22, 2008 | 01:36 PM
joshua022's Avatar
Just find a used 5.3, 6.0 or ls1 crank and swap that in your motor. Then you'll have a 5.3 with a little higher compression then normal because of the flat-top pistons.
^^^ Would be your cheapest route IMO.
Old Jan 22, 2008 | 02:41 PM
SS_bnoon_SS's Avatar
You can't put 4.8 pistons on a 5.3 crank or the pistons will contact the heads and stick out of the top of the block!!! If you want the longer stroke, you need the matching pistons and rods of the LS1 or 5.3.
The REAL option should be a stock LS1 entire rotating assembly and bore the 4.8 block out to 99mm for 5.7L/348 cu in, or go stroker assemble and bore the block for bigger cubes.
