looking for a used 5.3 or 6.o.
You can't put 4.8 pistons on a 5.3 crank or the pistons will contact the heads and stick out of the top of the block!!! If you want the longer stroke, you need the matching pistons and rods of the LS1 or 5.3.
The REAL option should be a stock LS1 entire rotating assembly and bore the 4.8 block out to 99mm for 5.7L/348 cu in, or go stroker assemble and bore the block for bigger cubes.
maxspeed05V
Sep 23, 2015 10:48 AM
OVOAustin
Sep 15, 2015 08:32 PM
