Look what I found in my oil pan !
Old Aug 24, 2010 | 11:55 AM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by Coban
Its primarily designed to eliminate the chain whip that occurs under RPM fluctuations. This whip is apparently what breaks chains.
OK, I get it...any idea how much it costs? I'd have to buy the wedge and the bolts...
Old Aug 24, 2010 | 12:54 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Can you post up a comparison pics of the Iwis chain versus the LS2 chain? I dont see how much better of a chain you can make without going to a different cam and crank gear.
Old Aug 24, 2010 | 01:00 PM
Mrgoodwrench3's Avatar
GM # 12588670
It is called a dampener. Cost is about $12.00 and it comes with 2 new bolts.
Old Jan 15, 2011 | 01:34 PM
TX Tahoe Z71's Avatar
Originally Posted by Mrgoodwrench3
GM # 12588670
Digging this up. Are the 5.3 blocks (2003 to be specific) already drilled for the LS2 style damper? It does not sound like the LS1 blocks are, but I couldn't find anything about the 5.3's.
EDIT: After more research, it seems like our blocks, at least the pre 2005, are not drilled and tapped.
Old Jan 16, 2011 | 07:13 AM
Country Boy's Avatar
Senior Member
Since when did they start putting tensioner in there? Ive been out of this for a long time.
Old Jan 16, 2011 | 07:43 AM
supercharged680's Avatar
07+ i believe
spent21
Aug 19, 2015 02:37 PM
GMCtrk
38
Aug 9, 2015 08:50 PM
Ls3silverado
Jul 31, 2015 04:22 PM
05SilveradoSS
Jul 29, 2015 08:34 PM
jmarkway
Jul 18, 2015 09:23 PM
