Look what I found in my oil pan !
I pulled the motor last week on my truck. I am doing a cam swap and some head work. Motor is a LY5 with 60K miles. When I removed the oil pan I heard something metallic rattling around inside. WTF? I pulled it out and it looked like a main bearing. After looking a little closer it was part of the timing chain tensioner that was broken. I never had any noise or symptoms of a problem. When the new cam go's in I have upgraded to the Iwis chain and the LS2 tensioner.
No I am going to run this Iwis timing chain and 1218 springs.
http://sdparts.com/details/scoggin-d...enter/sd3sr602
It looks like the entire assembly could have come apart. Might be a good thing you took it apart when you did! Your chain and gear look to be in pretty good condition for the mileage.
