Loc tight crank bolt?
Old Mar 8, 2004 | 11:37 AM
getsome's Avatar
Default Loc tight crank bolt?
Ok i am putting on a sc and i was wondering if it will do any good to loc tight the crank bolt so it doesn't back itself out? I will that do any good to do that?
Old Mar 8, 2004 | 01:05 PM
1BADHD's Avatar
If you torque it down to waht is says........you wont need any loctite.
Old Mar 8, 2004 | 07:35 PM
Grey Silver's Avatar
11 Second Club
Buy a new bolt and torque it to spec. If you want to use the old one put the lock tite on the flange of the bolt and make sure the face of the pulley is clean. Putting it on the threads won't do any good. The bolt will stretch and squeeze out the lock tite.
Old Mar 8, 2004 | 07:48 PM
Flyer's Avatar
You'll need lots of luck to get that thing torqued to spec too.
Old Mar 8, 2004 | 07:54 PM
I drilled and pinned mine I got the kit to do it with from Magnacharger.With the truck on a lift you can torque the bolt to spec.
Old Mar 8, 2004 | 08:04 PM
Flyer's Avatar
Whitt ... would youmind telling me what the injectors and pin kit are? Brian sent me a quote for both pieces and I'm not sure which does what and exactly what I need.
Old Mar 8, 2004 | 09:03 PM
The pinning kit has a longer than stock bolt,a drill guide that is bolted to the snout of the crank with the pulley in place,a hardened drill bit to drill through the guide to drill a holes between the crank and pulley,a reamer to deburr the holes,2 hardened roll pins to go in the holes and a stock length bolt to hold the drilled and pinned pulley on the matched and pinned crank snout.Go to the Magnacharger website and click on the Corvette installation PDF for detailed instructions.
Old Mar 8, 2004 | 09:04 PM
The pinning kit has a longer than stock bolt,a drill guide that is bolted to the snout of the crank with the pulley in place,a hardened drill bit to drill through the guide to drill a holes between the crank and pulley,a reamer to deburr the holes,2 hardened roll pins to go in the holes and a stock length bolt to hold the drilled and pinned pulley on the matched and pinned crank snout.Go to the Magnacharger website and click on the Corvette installation PDF for detailed instructions.I don't know what injectors you are talking about.
Old Mar 8, 2004 | 11:50 PM
Flyer's Avatar
Me neither ...
I think it's just the pinning kit I would need.
Old Mar 8, 2004 | 11:58 PM
getsome's Avatar
Ok i wasn't real clear on this quistion. I am putting on a sc this weekend and i do have a new bolt going on because i am taking off the asp pulley. What i am asking is will it be any better to put loc tight on the bolt so it has less of a chance to back itself out? I know i can get it pinned but don't have the flow to spend to do that.
5.3Okasai
Mar 9, 2022 01:07 PM
Jblake
Aug 17, 2015 12:59 PM
vipergtrdj
Aug 6, 2015 10:19 PM
4B11T
Jul 13, 2015 03:48 PM
GreyChevy
Jul 7, 2015 08:57 PM
