Lifter play
I have a 5.3 and i recently replace all the lifters becuase it was having a ticking that sounded like the lifters, rocker arms seem ok and i had a mechine shop check and resurface the heads and i let the lifters soak in oil before installing them now it sounds even worse it sounds like every single lifter is ticking instead of the 1 or 2 that i heard before and i have a little bit of play pusing down on the push rod with the rocker arm off. Can it be bad new lifters i bought melling which is a pretty good brand what can this be i also have good oil presure and it has a mild cam
silverado2000
26
Feb 12, 2013 01:36 AM
BrittSSter
Nov 19, 2003 02:43 PM
Slowverado
May 28, 2003 08:46 PM
