Lifter play
Old Jun 15, 2018 | 10:28 PM
Crysis450's Avatar
Default Lifter play
I have a 5.3 and i recently replace all the lifters becuase it was having a ticking that sounded like the lifters, rocker arms seem ok and i had a mechine shop check and resurface the heads and i let the lifters soak in oil before installing them now it sounds even worse it sounds like every single lifter is ticking instead of the 1 or 2 that i heard before and i have a little bit of play pusing down on the push rod with the rocker arm off. Can it be bad new lifters i bought melling which is a pretty good brand what can this be i also have good oil presure and it has a mild cam
Old Jun 16, 2018 | 06:43 AM
03sierraslt's Avatar
What’s the preload?
Old Jun 16, 2018 | 09:18 AM
Crysis450's Avatar
Not sure didn't measure it do you think it needs different length push rods
Old Jun 16, 2018 | 11:55 PM
Crysis450's Avatar
Anyone? Are lifters soupose to have this play on the top where the push rod lays old ones didnt have this
Old Jun 17, 2018 | 12:02 AM
FFDP's Avatar
It's a hydraulic lifter with a spring, it's going to have some movement.
This video shows the parts.
Old Jun 17, 2018 | 08:24 AM
Crysis450's Avatar
Interesting I'm going to probably have to pull the hole engine and recheck everything it might be a bearing then i thought these lifters shouldnt have play since the old ones didnt
Old Jun 17, 2018 | 11:02 AM
Why don’t you check lifter preload before pulling the motor.
Old Jun 17, 2018 | 11:49 AM
Crysis450's Avatar
Well i didnt change the push rods and i never had this problem before so i dont see why the preload will be the problem this motor has seen boost before so i believe it might be something else
Old Jun 17, 2018 | 01:00 PM
Crysis450's Avatar
Looks like you guys might be right when the lifter is on the low side of the cam it looks like the rocker arm isnt snug with the push rod theres some movement
Old Jun 17, 2018 | 02:37 PM
Funny enough as it is a lot of the stock motors out there are running .110-.120 which is way to much. .080 on stock lifters or stock replacements is preferred. My stock LQ4 had .115
silverado2000
26
Feb 12, 2013 01:36 AM
BrittSSter
Nov 19, 2003 02:43 PM
Slowverado
May 28, 2003 08:46 PM
1999stepside
May 15, 2002 03:10 PM
