Lets Play Name That Broken Part, Chapter 2, The Install
Old Dec 6, 2005 | 06:37 AM
  #61
1SlowHoe's Avatar
Destroyer of Transmissions
Originally Posted by whitt1
The increased valve duration is what makes it louder.My truck got alot louder with a big cam.
Do you think a 210/218 47* .551/.551 112lsa is big enough to account for the noise?
Old Dec 6, 2005 | 12:05 PM
  #62
BigKID's Avatar
My truck got louder with the 214/216 in the 5.3 and it is even louder than that now with the 5.7 and 228 cam. The 6.0 are more prone to droan as well.
Old Dec 6, 2005 | 12:13 PM
  #63
Mr. Sandog's Avatar
This is what I've heard as well. I remember reading about how exhaust manufacturers were have numerous problems building catbacks for the 6.0L, as it was very difficult to tune out the drone, resonance, and overall noise.
Old Dec 6, 2005 | 01:27 PM
  #64
Mort's Avatar
Cool
The 6.0 is very loud and does drone alot. A big Magnaflow will not tame it. If you want it quiet you might want to consider a HD Big Oval series Flo Pro Muffler. I have heard that they do a good job of keeping a 6.0 quiet.
Old Dec 6, 2005 | 01:31 PM
  #65
Mr. Sandog's Avatar
Two Magnaflows in series might though.
Old Dec 6, 2005 | 01:48 PM
  #66
1SlowHoe's Avatar
Got Pacesetters on the way. I was thinking about running duals with an X pipe and two Magnaflows (one on each pipe, not inline) and having a dual exit on the pass side behind the tire. Keeping the cats but might go high flow to replace stock ones.
Think that would quiet it down?
Lose bottom end TQ?
Old Dec 6, 2005 | 02:07 PM
  #67
Mr. Sandog's Avatar
Lose bottom end TQ?
Instead of the x-pipe you could get a Magnaflow 2-in, 2-out, which has a built-in x-pipe inside the muffler. Together with two more mufflers (one on each pipe), you'd probably be in business for quiet...and I doubt you'd lose any bottom end, might just gain some.
Old Dec 6, 2005 | 02:35 PM
  #68
BlownChevy's Avatar
blownerator
25 Year Member
and lose some top end from the additional back pressure.
Old Dec 6, 2005 | 02:46 PM
  #69
Mr. Sandog's Avatar
Kindly explain how you gain any backpressure from a straight-through exhaust.
Old Dec 6, 2005 | 04:51 PM
  #70
Scott Mills's Avatar
I had to use use a large dual in/out magnaflow and a couple of glasspacks in-line to kill the drone of my old 6.0
