Lets play...Name that broken part
Old Nov 1, 2005 | 11:08 PM
  #331
treyZ28's Avatar
M10. I cant remember if its 1.25 or 1.5. Length- uhh not that important but a 100mm bolt might be a bad idea as would a 10mm bolt.
bolts are a few nickles anyway. get both
Old Nov 2, 2005 | 02:56 PM
  #332
1SlowHoe's Avatar
Destroyer of Transmissions
Should I get a stall while I got it all apart? I see the Trailbalzer stall sells for $200 new?? I thought stalls were $500+ If I did one it would be small, 2400. Whats the Trailbalzer rated at?
Old Nov 2, 2005 | 03:01 PM
  #333
Fogle07's Avatar
might as well do it while you got it apart. i think a trailblazer stalls to like 2500 but im not sure. if you want to get a new one then maybe a 3000?
Old Nov 2, 2005 | 04:51 PM
  #334
TurboGibbs's Avatar
You'd be crazy not to.
Old Nov 2, 2005 | 04:54 PM
  #335
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
The tb stall should go to 2500 or so with your setup.
Old Nov 2, 2005 | 05:53 PM
  #336
1SlowHoe's Avatar
Do I just go to the stealership and say "Give me a trailblazer stall, and be quick about it" or is there a website that wont charge me $500 for a $175 part? Part # anyone? This will bolt onto a 65E correct?
Old Nov 2, 2005 | 06:35 PM
  #337
I'm glad to see you talked to Joe Vinci about your cam and glad he had installed that grind in a Radix before.Experience is the best indicator in cam selection because using just the numbers never tells the complete story.The Trailblazer convertor is probably a good selection for your truck,will probably flash to 3000 rpm under boost and give near stock drivability.I'm currently running a 2.75" pulley with a Gatorback belt with no problems.It sounds like you are on the right track.
Old Nov 2, 2005 | 10:00 PM
  #338
kbracing96's Avatar
Go to eBay and look up this guy, eli2112. He sells DACCO reman stalls. He doesn't have the one I got listed on ebay right now, but he says he has them, just email him. The one I got is the 2200rpm TB stalls and it works great. I can brake stall it to 3K and 5lbs of boost. Zippy on SSSiverado.com puts them in the Radix's SS trucks with much success. I believe I payed $140 plus shipping for it, and I love it. It's a little higher around town then stock, and when you hammer it it really comes to life.
Old Nov 2, 2005 | 10:02 PM
  #339
treyZ28's Avatar
quick question- can the trans be slid far enough back to do the swap? or am i pulling the trans out of the crossmember
Old Nov 2, 2005 | 10:15 PM
  #340
kbracing96's Avatar
I was able to slide the trans back and drop the front down far enough to swap the convert, with out taking off the t-case or the torsion bar cross member out.
