Lets play...Name that broken part
Old Oct 31, 2005 | 08:40 PM
  #301
Originally Posted by Naked AV
Just call him "Mr. Lopey"
You will have a choppy idle and the narrow lobe separation will bleed off some boost.After you get it running check out how much boost you are making I've got a couple of Radix pulleys laying around if you need to raise the boost.
Old Oct 31, 2005 | 08:53 PM
  #302
1SlowHoe's Avatar
Destroyer of Transmissions
I've got a 3.25, 3.0, and 2.75 in my garage. So I should be ok. I think I might just got for 6-8 pounds this time. I'm thinking, (correct me if I'm wrong) that a 6L with 6#'s should feel as strong as a 5.3 @ 9#'s. I've seen a few guys pushing 10#'s on their daily driver (MJHoward, etc..) and no issues. I guess if I have the fuel system in place and don't go over say, 11.7 afr, I could safely push 10#'s into the LQ4 and get away with it. I haven't really made up my mind yet. This will be my first motor with a non-stock cam as well.
Old Oct 31, 2005 | 09:04 PM
  #303
Your 6.0 with 6lbs of boost will be stronger that a 5.3 with 9lbs of boost.The 3.25" pulley will probably give you 6 1/2 lbs with the cam you are planning to run.
Old Oct 31, 2005 | 09:07 PM
  #304
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Go ahead and drop the 2.75 on it and have fun
Old Oct 31, 2005 | 09:22 PM
  #305
1SlowHoe's Avatar
http://www.vincihighperformance.com/...6%2004%202.avi
Little sound clip of the cam
Well IF I ever get an engine I will let you know how it feels.....
Old Oct 31, 2005 | 09:44 PM
  #306
moregrip's Avatar
what a rush!
as a point of reference, I have 7lbs of boost with the stock cam and a 3.1 pulley
Old Oct 31, 2005 | 09:50 PM
  #307
10 lbs here easy on 212-218 Cam. the 6L Rocks!
Good luck
Old Oct 31, 2005 | 10:01 PM
  #308
1SlowHoe's Avatar
Good luck
I see you have meth. I dont know that I would be willing to go 10#'s without meth or N2O (for cooling purposes only ) I have the wet kit in the garage.....
Old Oct 31, 2005 | 10:04 PM
  #309
1slow01Z71's Avatar
That clip it seems like they have it idled up too high. It should sound alot lopier and not so quick IMO.
Old Oct 31, 2005 | 10:11 PM
  #310
Good luck
The 112 narrow lobe separation yields more overlap than a wider lobe separation,that's what bleeds off boost.That's why the Linginfelter cam Blownchevy suggested is a better cam for a Radix.
