Lets play...Name that broken part
Old Oct 31, 2005 | 02:00 PM
  #291
1SlowHoe's Avatar
Destroyer of Transmissions
Originally Posted by parish8
those heads would work but you dont want them, they would raise your compresion. all the heads interchange and the intake would bolt on fine.
$1500 for an 03 lq4 isn't a bad deal, what are you waiting for?
Litredevil is supposed to be getting me a shipping quote and all the details today. If it all sounds good I will get it. Hope to know soon.
Didn't know about the compression raising on those heads. No good for me then.
Old Oct 31, 2005 | 05:23 PM
  #292
1SlowHoe's Avatar
Default cams here..
Got the cam today. I guess I was expecting a bright shiny shaft. I hope they didn't send me the used one they have in there "Specials" section. The "Special" (used) cam is the same grind as this one a #62. What do yall think has this been used? Less than 100 miles according to the special. I've never seen a brand new cam before so maybe I'm retarded.
Old Oct 31, 2005 | 05:40 PM
  #293
Scrapin'4.8's Avatar
Don't look too new to me.....but i don't know
Old Oct 31, 2005 | 06:48 PM
  #294
LVSTOGOFST2002's Avatar
i saw on a write up from comp or something, the cams are coated in copper or some other reddish metal before grinding ( part of the hardening process if i remember correctly? ) are the lobes nice and even and no marks on them?
Old Oct 31, 2005 | 07:57 PM
  #295
It's probably new if it were used the lobes would be polished by wear.What's the lobe separation on that cam?
Old Oct 31, 2005 | 08:02 PM
  #296
TurboGibbs's Avatar
Cams come with an anti-corrosion coating which makes them not so shinny. And the lobes look brank new from what I can tell. Clean it off with some carb cleaner before you lube it up and put it in. I think i've heard that before somewhere
Old Oct 31, 2005 | 08:10 PM
  #297
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
You would need more than carb cleaner for what you got
Old Oct 31, 2005 | 08:29 PM
  #298
1SlowHoe's Avatar
@ .050 210/218 112LSA
Old Oct 31, 2005 | 08:30 PM
  #299
Mr. Sandog's Avatar
Originally Posted by 1SlowHoe
....112LSA
Just call him "Mr. Lopey"
Old Oct 31, 2005 | 08:32 PM
  #300
1SlowHoe's Avatar
The lobes look perfect. Every other part looks dirty. Covered in oil residue or something. I'm sure it will look fine once I clean it up. Push rods and gaskets should be in tomorrow. Wish I had an engine to put them in...
