Lets play...Name that broken part
Old Oct 27, 2005 | 11:42 AM
  #131
moregrip's Avatar
what a rush!
Originally Posted by 1SlowHoe
Just spent the last hour on the phone with Joe Vinci. After talking it all over I went with the ASP Kicker cam and thier titanium springs. He said these will work with stock pushrods and rockers. After I told him I would be shooting for 8#'s of boost on the LQ4 he said the ASP was they way to go. Should have a little chop to it and it pulls from 1900-6000. Also found out I will need a water pump gasket, Crank bolt, Valve seals, Timing cover gasket and seal.
Guess I need to go to the dealership or GMPartsDirect.com. Anybody got part numbers?
CAM SPEC:
DUR @ .050" 210*/218*
LIFT .551 / .551
OVERLAP 52*
LSA 112*
with -10deg it should be good with the radix. and your using stock rockers?
what are the .006 specs?
Old Oct 27, 2005 | 11:56 AM
  #132
Mr. Sandog's Avatar
Just get the Scoggin Dickey Cam Replacement Gasket Kit here. Should have everything you need.
Interesting cam choice....with a 112 LSA you should have all the lope you'd ever want.
You sure you need $300 springs on a cam with .550 lift? LS6 springs are dirt cheap and the 918's are only $159.
FWIW, most everyone I've talked with has said replace the stock pushrods with hardened ones while you're in there.
Old Oct 27, 2005 | 12:44 PM
  #133
NoChrome's Avatar
Id have to agree, better safe than sorry. With as much as you have already spent whats a little more for some security?
Old Oct 27, 2005 | 01:01 PM
  #134
1SlowHoe's Avatar
Destroyer of Transmissions
Yes, using stock rockers. Joe said they would be fine. I didnt want to spend another 600 for the rockers and pushrods just yet. I have to watch the $$ a little bit.
The other specs listed are:
DUR @ .004" 272*/280*
Old Oct 27, 2005 | 01:03 PM
  #135
NoChrome's Avatar
At least now you got a good excuse to replace the rockers, cause your push rods might be weak. I bet that one beats the "Shut up woman go mow the yard" line.
Old Oct 27, 2005 | 01:16 PM
  #136
1SlowHoe's Avatar
The pushrods I would need for the new rockers are not the same as the stock size. So, if I were to buy hardened push rods now they would be no good to me in a few months if I go with the 1.8 rockers. When I decide if I'm gonna spend the 600 bucks for rockers is when I'll figure out which push rods to get. I think I should be ok for awhile. I seem to see alot of guys with more lift than me running stock push rods and rockers.
Old Oct 27, 2005 | 01:55 PM
  #137
Fogle07's Avatar
hardened pushrods only cost 90 bucks shipped from texas speed. might want to look into them. up to you though. good luck with everything
Old Oct 27, 2005 | 01:58 PM
  #138
moregrip's Avatar
what a rush!
LS6 springs are dirt cheap.
I agree, these would be an excellent choice.
Old Oct 27, 2005 | 02:08 PM
  #139
1SlowHoe's Avatar
Vinci was telling me $160 for the push rods alone.
I just got off the phone with ARP and they dont make rod bolts for a 2004 LQ4 or the lady didn't know what she was talking about.
Old Oct 27, 2005 | 02:11 PM
  #140
Fogle07's Avatar
talk to jason at texas speed. thats where i got mine from. he even let me have some stock valve locks and retainers. you should just tell her that is a LS1 i think thats how they got them listed
