Kooks Header Install ?'s
I am about to be installing the Kooks LTs with the catted Y pipe. Do the Kooks headers comes with gaskets? Also, which O2 extension harnesses are needed? I want to make sure when I go to start the install I can finish it and I'm not without the right parts. Thanks for the help.
Sure don't have experience on your specific vehicle but Kooks does provide gaskets...
With that said. DO NOT USE them. Nothing better then your stock MLS gasket, re-use them if there not dinged up or have obvious leaks, you'll see the carbon escaping on the gasket.
Or pick up a new set of stock gaskets.
On the extensions I can't be of much help my app. didn't require them.
Give your self plenty of time to finish, Mine were somewhat tight and things had to be un-bolted,lifted,lowered all that jazz. Just one side though.
Enjoy them! Kooks makes a quality piece.
zblee
63
Jun 10, 2023 01:25 PM
ARC
57
Feb 21, 2022 10:54 AM
zblee
Aug 3, 2015 03:45 AM
