Knock retard on stock denali...?
Old Nov 27, 2004 | 10:19 AM
syclone01's Avatar
Default Knock retard on stock denali...?
2001 stock yukon denali....6.0L 58k miles.....I get knock retard at throttle tip in.....and also at WOT throughout the gears....Shows anywhere from 3-5 degrees of knock retard. I can be cruising at 70, and just real quickly push down on throttle, like 1/4 throttle for a sec or so, not enough to kick down trans or anything and it will show 1-2 degrees for a sec. I would like to do a few things performance wise, but want to get the knock retard issue resolved first. My Z06 never gets knock retard. Any areas prone to cause this with the 6.0L?? It still has stock plugs and thermostat. I have a cooler thermostat, just haven't put it on yet, want to fix problem first. It can be 60 degrees out and the intake air temp is 60 also, it will do it still. ANy ideas where to look first? Does it with all brands of gas.
thanks, damon
Old Nov 27, 2004 | 11:39 AM
budhayes3's Avatar
PT's Slowest Truck
Maybe somethings banging around under there? Loose exhaust hanger or something like that?
Old Nov 27, 2004 | 12:27 PM
syclone01's Avatar
Default loose
no, don't think it's that. checked it out underneath...never hear any noise at all. It only does it on throttle tip in, or WOT....I can go over bumps or railroad tracks and never any KR or noise....just thought that maybe these 6.0L have a few things common that might cause the knock retard.
Old Nov 27, 2004 | 01:29 PM
gonzo 6.2's Avatar
When my buddys 02 denali was stock I remember looking at a scanner and seeing what you are talking about.No problem now since we added AZ speed headers floproHD duel out the sides behind tires,yank 2600,AP 6.0 ported heads 220/560 comp,UPD,LS1 edit.SHE RUNS and get better mileage also.
You need a custom tune or edit.
Old Nov 27, 2004 | 06:33 PM
syclone01's Avatar
Default computer reprogram
recommendation on programmers for 6.0L? I've used pcmsforless for my impala ss with good results......bang for the buck is what I'm looking for.
Old Nov 27, 2004 | 06:59 PM
gonzo 6.2's Avatar
He knows trucks,he has a strong SS truck.
Old Nov 27, 2004 | 07:08 PM
superchargedchevy02's Avatar
I like MTI
Old Nov 27, 2004 | 07:12 PM
one03sierra's Avatar
Formerly one92rs
Talking
i like nelson.
OHsixLS3
Dec 27, 2016 09:30 AM
The_W
Oct 28, 2015 09:00 PM
superchomper2003
Aug 26, 2015 09:39 AM
04450r
Jul 30, 2015 02:04 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
