iron L33 build ?'s
Old Dec 8, 2012 | 06:24 PM
way2much_01's Avatar
Default iron L33 build ?'s
got a couple of ? on my build started to install oil pump and wondering is it worth installing the stiffer spring that comes with the HV oil pump or no? next is I need to know what goes in the hole on top of the block next to the cam position sensor? it doesnt look like a sensor more like a sight flow indicator of some sort. next is in the how to build ls engine manual it says to use an old head gasket and old head bolt to bolt down the head to measure PR length, well I dont have any of the old bolts nor gasket so all my parts are new will I be able to torque the heads down them measure for PR length? and last but not least anyone have a part number for the gasket in the valley cover where the knock sensors go? thanks in advance
Attached Thumbnails iron L33 build ?'s-img_0807.jpg   iron L33 build ?'s-img_0808.jpg   iron L33 build ?'s-img_0810.jpg
Old Dec 8, 2012 | 07:22 PM
1FastBrick's Avatar
Custm2500's Rude Friend
I can't help you on the spring Question, but I have a thread with part numbers for gaskets and such. It's located in the stickies. https://www.performancetrucks.net/fo...umbers-428941/
Check with a dealer to make sure it's what you need. Sometimes Gm updates or changes the part number.
The one hole that goes straight down into the block is for the oil pressure switch.
BTW, you had a 4.8/5.3 block listed at one point. Is it still for sale???
Old Dec 8, 2012 | 08:28 PM
Thanks man I was looking for that thread must of over looked it. No the blocks gone didn't have anywhere to store it so I had to scrap it got tired of hauling it in the bed of the truck
Old Dec 8, 2012 | 10:02 PM
What about the PR problem?
Old Dec 8, 2012 | 10:14 PM
1FastBrick's Avatar
Damn. I need that.
You can put the head's with new gasket on and measure. No need to remove the head.
I think there was a thread describing how to do it.
Old Dec 14, 2012 | 12:16 PM
Tkosinski2's Avatar
I'm interested in doing this same thing. I know there is a differance between the lm7 and L33. Can you post part numbers for cams, heads, etc that would be different from the Lm7?
What's PR?
Old Dec 14, 2012 | 12:35 PM
53bowtie's Avatar
PR stands for push rod.
This is quoted from ARCHAIC on fullsizechevy:
The Gen III Vortec 5300 is available in a new lighter, higher output variant optional on some 2005 Silverados and Sierras. RPO L33 will be introduced in short bed, extended cab versions of these pickups. The L33 features an aluminum engine block, new cylinder heads and a high-lift cam. Torque will increase, and horsepower is expected to exceed 300 in final production trim.
One of the L33’s distinguishing features is its engine block. As with the 2004 LM4 Vortec 5300, the L33’s foundation is a cast-aluminum block with pressed-in iron cylinder liners, similar to the block used for GM Powertrain’s LS1 and LS6 car V-8s. The L33 block is exceptionally light; as a result, a fully dressed L33 is 100 pounds lighter than cast iron-block Vortec 5300s (RPOs LM7 and L59).
The L33 takes its cylinder heads from the LS6. Originally developed for the Z06 Corvette, these heads improve airflow in and out of the engine. With their pent-roof combustions chambers and new flat top pistons (the pistons in other Gen III Vortec 5300s have a slight sump in the piston deck), the L33’s compression ratio increases from 9.5:1 to 9.9:1. This increase improves the engine’s volumetric efficiency yet still allows it to achieve full power with regular grade gasoline.
Finally, the L33 is equipped with a higher-lift camshaft. Maximum valve lift increases from 11.6 mm on the LM7 and L59 to 12.5 mm. The new cam and compression ratio are the primary sources of the L33’s increased horsepower.
The L33 camshaft and cylinder heads were developed in conjunction with the new Gen IV Vortec 5300 (RPO LH6). The design objective was more horsepower for customers who need it, without requiring a step up to the Vortec 6000 (and an increase in operational costs). RPO L33 expands GM Powertrain’s lineup of Vortec V8s and gives GM’s truck customers even more flexibility and choice.
The L33 Vortec 5300 will be built at Powertrain’s Romulus, Mich., engine plant. With its introduction, Powertrain will cease production of Vortec 5300 RPO LM4. The Buick Rainier, Chevrolet Trailblazer EXT and GMC Envoy XL, previously equipped with the LM4, will now be powered by the Gen IV Vortec 5300 with Displacement on Demand. The 2005 Chevrolet SSR will be powered by the new LS2 truck V-8.
Old Dec 16, 2012 | 09:15 AM
What's PR?
Basically all you need Is a 4.8 pistons and either 243/799 heads
Go5.3tt06
25
Sep 4, 2016 10:25 AM
2500ZL1
Sep 12, 2015 03:50 PM
GMCtrk
Sep 11, 2015 09:04 AM
MA$TER_E
Sep 9, 2015 03:14 PM
the owl
Sep 4, 2015 04:09 PM
